Has anyone swapped out the rear axle???
8890 Views 29 Replies 14 Participants Last post by  flecker
I am considering swapping out the rear axle for something with 4.10s that I can get an aftermarket locker in. Has anyone tried this and found an axle that fits fairly well? I would prefer to keep the 6 lug pattern but so far it looks like my best options are going to be a 5 lug since I don't want to have to get it shortened. What has anyone else used?
1 - 20 of 30 Posts
So if I'm reading your post correctly, you want to swap your rear axle with one from another vehicle?
That's right...just trying to see what anyone else has used on knows would fit reasonable well. Sorry if it's confusing.
From what I understand the S10 axle will work, but its 5 lug.:shrug:
If an S-10 axle will fit, so will an F-body or G-body 10-bolt if you swap the spring perches over... they're also 5-lug though...
Much stronger too. Go with a Moser FTW!
5 lug conversion all around wonder if anyone has done it
hmmm... wonder if s-10 front hubs will fit over our spindles with no modification? If not, I'm sure you could get custom bearings made to make them fit....
Couldnt you just buy new gears and a locker? I would think that would be a lot easier.
The problem is that no one makes a locker for the Colorado axles and used axles aren't too expensive, depending on what you get.
Any other ideas for a 6-lug pattern that might work?
what about a rear axle off a nissan hardbody?
Easy fix, buy a G80 and some 4.10s:shrug:
I think the OPs looking for something stronger than the G80.
The G80 isn't too bad, but I am looking for something a bit stronger. There are plenty of options on almost any other axle made and the Colo's axle looks pretty simple to switch out.
I'm planning on swapping the rear out of my truck when I end up with more power than the I5 under the hood. So far a Ford 8.8 housing with custom Strange axles and an Auburn or Detroit chunk makes the most sense. 8.8's are a dime a dozen, and one from a Mustang or Ranger is within 1" of being the same width as our stocker.
That's actually what I was leaning towards but wasn't sure what to do with the axle shafts. You said custom so I assume you're getting new shafts made, any idea how much that usually runs? I don't have any idea. You can get almost anything for that Ford 8.8 but I wasn't sure how wide it was. Thanks for the info!
Strange'll throw a set of hardened 31 spline axles whatever length, whatever bolt pattern you want together for about $400 after shipping.
Strange Engineering P3102 - Strange Custom Axles
I'd love to do a full 5 lug conversion so I could run some Corvette wheels
does that include shortening the axle tubes??? and is the 8.8 narrower or wider??
there are 2 differant hardbody rears only the larger of the 2 had a locker available when i was into 4x4. im not sure on width though. this would be the best route if the width is right since they are capable of handling 500+hp.
Depends on the application it's sourced from. Mustangs/F150 are almost exactly the same, Rangers are slightly more narrow. Only reason I know is I have a Mustang 8.8 on stands in my garage. ;)
1 - 20 of 30 Posts
