1 - 2 of 2 Posts
My amp its in safe mode. i changed the ground and i been trasing wires everything looks good. it turns on(green) then red and back to green... it keeps doing it. the second amp 750.1 its working correctly.
any idea what might be wrong??
Member's Technical crew
Well the fact the light is coming on and off means its goin into safe/ defect mode..as long as its coming on like it should, and your sure its gettin voltage on remote AND power source, then it should come on. Since you already said you have a good ground of course.
if it's still not coming on, then there is a issue inside the amp. Make SURE you go back over the wiring one more time..Then maybe swap the amps you have if you want. just the leads of course to make sure your feeds are good.
1 - 2 of 2 Posts
