1 - 20 of 36 Posts
Well the rado's lens could use a good polishing so I picked up some Meguiar's headlight restoration stuff going to test it on the Jimmy first though once my drill's battery is charged
Anyone else used the stuff?
i take the headlights out of the car, sand them with 1000 grit, sand all the facotry UV protect-ant crap off, and then mix up some clear coat and spray them with 2 coats, just as im spraying a hood or fender or whatever.
i do this when im repairing a front end, because the customers are freaked out that i did it, and its good for business.
well i tried it out seems to help a little but i think my drill might not be fast enough
Batman
tried that one and the Mother's kit
I don't think I was patient enough with them and gave up after about 20 minutes
they prolly both work fine, but I got bored and saw something shiney and got distracted, never got to finishing yet :lol:
I fucking atoadaso!
I paid the body shop to restore the driver sdie headlight on my stratus when I had the pass side replaced, it looked great for about a month then started to go back to what to used to look like, now about 6 months later it looks just as bad as the beginning. I dont know what type of products they used or if it was done correctly but that was my experience with it.
I've used something similiar to that, and it worked great!!
Like Forrest said, put some wax on after you buff the lenses. It holds up well, plus makes it easier to clean the shit/mud off the lenses.
:thumbup: thats what we do at work as well
the dealership i work at has one of the kits through the company we use called BG. the kit they have always works on any headlight i used it on. comes with a solvent to wet sand with(uses various grit paper) a cleaning solution, and a brush on coating.. its a lot more expensive then the kit you used though :shrug:
Yeah, if you want it to last you'll need to apply some sort of UV portection back to the light, wether it be clear coat or even something like laminix film will make it last longer.
1 - 20 of 36 Posts
