1 - 6 of 6 Posts
So last night I get in my truck to go to the store, as im pulling out of the apartments i notice that it still looks dark infront of my truck.. so i check to see if my headlights are on and they're not... im like what the duece???? so i try to turn the switch manually to turn them on and all they do is flicker then dim out... its like less than a second theyre on for.... i checked the fuses and they all seem fine...
any other ideas it might be??
Lord Bearded One
Check the bulbs. See if they are pushed in all the way. Maybe it's not making full contact.
you have HID's right? check your wiring...if its stock I dunno...I've had my share of problems...I ended up rewiring my headlights up so they come on all the itme when the keys in.
Discussion Starter #4
no i HAD hid's then they got stolen when i moved out here. i think my whole wiring might be messed up tho. i gotta pull my grill apart to check it out but the apt manager are BEOTCHES
What the F?!?! Someone stole you HID's? Holy shit man, I'm sorry, that's almost funny.
I had a similar problem. It turned out to be loose wiring.
1 - 6 of 6 Posts
