Welcome to the Nation. Truck is looking great. What model year?
Its misfiring on cyl 5, when it's showing cel. Its pretty intermittent.Welcome to the Nation. Nice looking truck. Run it by an auto parts store. Most of them will scan it for free and the code(s) should indicate which cylinder is misfiring.
Yes.. seems after i took to a mechanic, the cam phàsers are going out. So its a pull engine and do all chains, seals, phasers, and possibly bottom end bearings.. he quoted 3500$.....Have you tried swapping coils to see if the misfire moved to a different cylinder?
Looking into a completely rebuilt engine with upgraded oiling system from Badlands Industries..do rings and head too
You have a 2007, 3.7, with only 142,000 miles that "seems to be well cared for". The issue is a #5 cylinder misfire and the diagnosis is a $3500 repair or and engine change? Sounds a bit odd, but it's your truck and your money.Yes.. seems after i took to a mechanic, the cam phàsers are going out. So its a pull engine and do all chains, seals, phasers, and possibly bottom end bearings.. he quoted 3500$.....
Actually about 9 codes showing on proper scan tool. Cam phasers, timing out of spec, missfire, balance out of spec, low voltage in cam and crank sensors, low oil pressure at idle... Bare minimum, needs timing and balance chains and sprockets, and cam phasers, along with several new sensors. Mechanic quoted 3500$ parts and labor. A new reman engine is 42-4500$, and 500$ for engine swap. So my choice is 3500$ to keep this possibly tired engine running, or a warranted reman for 5k. The rest of the truck seems to be in excellent condition. So to me it seems the extra 1500$ for a 0 mile reman may be worth the expense.You have a 2007, 3.7, with only 142,000 miles that "seems to be well cared for". The issue is a #5 cylinder misfire and the diagnosis is a $3500 repair or and engine change? Sounds a bit odd, but it's your truck and your money.
That all said, at this point, i may just run this engine until it blows or quits and then do the reman swap. What's to lose, right? Although, at 142k, i would have to think that this engine isn't mechanically hurt.You have a 2007, 3.7, with only 142,000 miles that "seems to be well cared for". The issue is a #5 cylinder misfire and the diagnosis is a $3500 repair or and engine change? Sounds a bit odd, but it's your truck and your money.
Okay, I'm going ti have one last post on the subject of the engine.Actually about 9 codes showing on proper scan tool. Cam phasers, timing out of spec, missfire, balance out of spec, low voltage in cam and crank sensors, low oil pressure at idle... Bare minimum, needs timing and balance chains and sprockets, and cam phasers, along with several new sensors. Mechanic quoted 3500$ parts and labor. A new reman engine is 42-4500$, and 500$ for engine swap. So my choice is 3500$ to keep this possibly tired engine running, or a warranted reman for 5k. The rest of the truck seems to be in excellent condition. So to me it seems the extra 1500$ for a 0 mile reman may be worth the expense.
