1 - 9 of 9 Posts
So I was getting in and out of my truck all day opening and closing the rear door when all of a sudden when I tried to open it, it wouldn't.... It will lock and unlock. when it's locked, then handle will pull all the way out. when it's unlocked, it'll only go about halfway out. I've taken the door panel off from the inside and tried to get the latch to break free but no luck. Anyone have this happen or know what I should do??
Same thing happen to me today, but My truck is extended. Haven't had a chance to pull the door panel yet.
did you check the child lock, maybe that thing get stuck the middle of both positions.
Was not aware it had child locks. I'll check work.
crew cab and extended cab are totally different systems.
I think you guys have two different problems in your doors.
yeahh my doors still stuck 6 months later... I've tried everything short of cutting the latch out with a sawzall.
1 - 9 of 9 Posts
