1 - 7 of 7 Posts
Installed my new hid 's and they work fine except I wanted them for the low beam and ended up with the hid for the high beam. Can I switch the sockets or should I put it back to oem and start over and try again. Not sure if the hi beam and lo beam use the same type bulb.
You can put the hi beam bulb in the low beam socket, you'll just have to loosen the screws that hold the bulb down and tighten them back down after is in place.
Formerly Metal_EMT
DDM Tuning actually labelled their bulbs as 9005/9006 when I received them. Just needed to do this to mine as I got the same bulbs for low and high beam.
1 - 7 of 7 Posts
