1 - 7 of 7 Posts
Left work tonight and my passenger side HID flickered a couple times then went out. I turned the lights on and off and it flashed like it was going to come on, then went out again. I do have some moisture from a heavy rain yesterday.....could that cause it??
Hmm the moisture shouldn't really affect it too much, I'd swap bulbs and see what is causing the problem. It's possible your ballast (and/or possibly igniter) is bad. If the bulb works, you'll know you just have a blown/shitty HID bulb
yeah, good idea, I'll try that and see what happens.
I had that problem once, I just turned it off for a minute then turned them back on and they seemed to fire up no problem. Like said try swappin stuff out and see if that works.
Mine doesnt fire sometimes... I just re-fire til it comes on sometimes takes 2 sometimes takes 7-8 :lol: My kit is getting on the older side so I expect it.
The headlight that had all my condensation in it, the bulb exploded inside it. But mine were halogens
1 - 7 of 7 Posts
