1 - 20 of 49 Posts
walking is for the poor
So I was driving today and made a right hand turn then my horn goes off. I make a couple more turns and it does the same thing. Does anyone know what this could be from?
my friend had the same problem in his 68vw, his ground wire for the horn was exposed in the steering colum so when he turned it would ground out thus causing the horn to go off
Thanks for the info. I'm going to take it back to the place I had my steering column installed.
3'' of glory
:lol:
this was happening to my 83 s-10. finally one day i got sick of it, pulled over, popped the hood, jerked it out, and threw it in the holler. try that if all else fails.
Discussion Starter #6
:lol:
:lol: thats pretty funny. you know you could of just pulled a fuse.
its probably the clock spring in youre truck is atone turn to far to the left and it is probably ging to ruin the clock spring. when the people put youre steering column in they probably had the wheel turned
Discussion Starter #9
damn That really sucks I just spent $200 for the clock spring to. I guess I'll have to take it back into them. the first time they didn't even look at it and said that it was a bad harness.
you may be able to save it. if the horn still works that means its most likely still good yuo just need to rotate it back after taking the steering wheel off. check to see if youre horn still works beforwize. also unplug the battery.
Discussion Starter #11
yeah the horn still works. I'm just going to have the body shop its at fix it on monday. Will I have to get it realigned after I do that?
yeah you have to get the clockspring realined. if you have a garage full of tools around you id suggest doing it now because you can damage it with the driving around. if youre goin to drive it around doint turn all the way.
Discussion Starter #13
well I don't have my truck right now its getting painted so I'm not going to be driving it around. so it would probally be better for them just to do it instead of driving it back home and doing it my self.
Discussion Starter #14
oh yeah my airbag light is on could that possibly mean the clock spring is damaged?
that means that the clock spring is ruined. you need to get a new one. man i feel for you. im on my 3rd right now also. you should make the people who installed it get you a new one. i guess its always something. youre in ohio arent you?
Discussion Starter #16
I'm in oregon. I really would hate to go back to them but I might to have them pay for it. When I took it back they said there was no problem with the installation and blamed it on the used cruise stem I bought. acting like it was my fault. do you think my extended warrenty would fix it. because the shop I took it to has nothing to do with the dealership.
knowing the dealership they wouldnt cover it most likly but its worth a try. if that doesnt work i would make that shop pay for the new one.
Discussion Starter #18
well I guess I'll have to wait for the stuff being painted and the go over to the shop and demand they replace it or refund my $200 for a new one.
Thanks for all you help I really apperciate it. :355:
Discussion Starter #20
I have the the tools well almost all the tools I guess I need an airbag puller. I also know the basics on how to do it. so I might just do it my self. do you know a good place where to buy a new clock spring?
1 - 20 of 49 Posts
