1 - 7 of 7 Posts
Administrator
Blue15ColoradoLT
Project Description
LED cargo light turn signal conversion
Skill Level
Easy
Make: Chevrolet
Model: Colorado
Year: 2015
Engine: V6
Power windows: Yes
Sun Roof: No
Tools Needed
philips screwdriver
flat head screwdriver
T20 Torx bit/ratchet
wire cutter
wire crimper
butt connectors
T-taps
wire ties
ratchet wrench or screwdriver, for this, I used a screwdriver
Red or Amber 921 bulbs, I used red
Project Time
60 - 90 minutes
Project Cost
approximately $30, depends on what LED bulbs you acquire
The actual install was quite easy. The more difficult portion was running the wire and hiding it to look professionally
NOTE: ****SHOULD YOU COMPLETE THIS MOD IDENTICAL TO THIS METHOD, YOU LOSE THE STOCK CARGO LAMP FUNCTION****
1. Using your T20 torx bit and ratchet, remove the 3rd brake light by removing these two T20 torx screws and giving it a little tug.
2. Twist all bulb connectors and remove from third brake light housing. Replace halogen bulbs with LED bulbs.
3. Remove harness from connector and proceed to run wire thru 3rd brake light opening
4. Drop rest of wire into cab
5. Using flathead screw driver, tuck wires under roof liner and inner body panels.
6. Lower back seat and pull back wall panel away from wall. Pull foam insullation away from wall enough to run the wire thru cab vent.
7. Run wires under the bed, zip tying to already existing wires run. I ran them down the driver side because the passenger side has the exhaust.
8. Lower tailgate. Using philips screw driver, remove philips screws in tail lights, repeat other side.
9. Pull off tail lights. Pull one of the wires up thru opening. Repeat other side.
10. T-tap wire into gray turn signal positive wire, repeat other side
11. On the 3rd brake light wire harness, cut the brown positive wires where you feel you need to. I cut them both right at the connectors:
12. Butt connect the run wires to the cut brown positive wires:
13. Reinstall 3rd brake light bulbs into housing and reinstall housing onto truck. Test results:
Legen..wait4it..Dary!
Well that's freakin cool.
thats awesome, would this work the same on an 06, keeping the stock harness and halogens?
1 - 7 of 7 Posts
