1 - 8 of 8 Posts
Administrator
Blue15ColoradoLT
Project Description
H11 Genssi LED projector headlights
Skill Level
Easy
Make: Chevrolet
Model: Colorado
Year: 2015
Engine: V6
Power windows: Yes
Sun Roof: No
Tools Needed
flathead screwdriver
T10 Torx bit/ratchet
Project Time
30 minutes
Project Cost
$79.95 + Shipping
Just like USAFquez did the HID installation, I'm using high powered LEDs instead. After 4 different orders from 4 different vendors, the first 3 all were out of stock on the 5000K H11 bulbs I needed. 4th vendor was Computer Parts, Laptops, Electronics, and More - Newegg.com which finally had them. These are also the same LED bulbs I have in my fogs and highs.
So here goes, Genssi H11 5000K LED conversion kit.
Best part is, this is a "2 gear design" so it can work with a standard reflector housing or projector housing:
Bulb in the housing change is pretty standard, you just have to add the extra connections of the LED drivers and connection harness:
LED bulbs are a little longer too due to the heat sink and fan:
The reason for the added connection harness, is that the H11 connection from the vehicle has the pins posted inside on the mounting position: (its hard to see but you'll see the silver posts "inside" the blue molds:
The connection harness it connects to switches the pegs so they are on the outside:
So start with the vehicle connection, and connect it to the harness connector, then the harness to the LED driver:
The LED driver has this awesome, one way only, screw sealed connection to the LED bulb:
After all of the connections are in, install bulb into housing:
Then I used double sided 3M tape, and taped the LED driver to the inner fender well:
Here is the light spread compared to a 5000K Philips diamond vision halogen bulb. Genssi LED on driver side, Philips Halogen on passenger side:
With LEG fogs:
COMPLETED INSTALLATION:
with fogs:
Those bulbs look pretty stout...lots of good features - great job!
Nice How To !!! Thanks for posting !!!
1 - 8 of 8 Posts
