1 - 20 of 22 Posts
mwcky2204
Project Name
Work Light
Project Description
Adding a work light, hood light to your 355
Skill Level
Easy
Make: GMC
Model: Canyon
Year: 2004
Engine: 3.5L
Power windows: No
Sun Roof: No
Tools Needed
Wire stipper/crimper
Side cutters
Rubbing alcohol
8" of double stick tape
4' wire loom, small black (or color of your choice)
in line fuse holder (opt.) will need 15amp fuse if used
2- batt. terminal connector's
2-wire connectors if fuse used
can also use shrink tubing to clean up wire connections
Project Time
30min or less (more like 20min)
Project Cost
$25.00 or less
The light used in this Mod is from 1988 GMC C1500 Sierra pkg. It can also be found on a Chevrolet C1500 Silverado pkg. truck yrs '88-90. I found this one at a local salvage yard for 18.00 incl the fee to get in the yard. They also can be found online from 12.99-14.99 plus shipping.
1.Clean the top of the fuse/relay cover with the rubbing alcohol
2.If using inline fuse holder attach or crimp a battery terminal connector to the hot and ground. you can run this strait to the battery. Do not connect to battery at this time.
3.You do not have to remove the factory tabs on the light as i did, but i think it cleaned it up a little. Clean the back of the light and apply double stick tape.
The light will have a 4' hot and ground. Cover the wires with the loom and tape at the ends just to keep it closed around the wire. Secure the hot and ground wire to the battery. You will have about 3' of extra wire. Just coil that up between the battery and the fuse box, this will be handy when you need to remove the cover for access. It is enough to set the cover on the front drivers side tire.
4.Peal backing from double stick tape and press firmly on to the top of the cover. I lined mine up with the left side (close to the engine) to allow for the most room when pulling out and retracting the light. Check all connections and your done.
You will have a light that you can always find and will be able to move it to any location on, in or around your truck.:thumbup:
I will be happy to help anyone that wants one of these lights find one:thumbup:
Re: How-Too Add a work light/hood light to your 355
Pretty friggin sweet cheap mod!
K
good idea did not even see it
Well done Mark. :355:
Those lights are worth their weight in gold. My '90 Silvy had one and it came in real handy one night at 1:30 AM when I had to change a flat tire.
Discussion Starter #9 (Edited)
your right man, had an '88 and used it alot. was supprised to find this one with the magnet still glued on the light, here is a pic of the donner truck..1989 C1500 Sierra pkg, was about the only thing left on it...
Batman
Woo hoo, just won my light like this on Ebay, gonna be almost as cool as Mark in a few day :bang:
The one on my Silvy had enough cord so the light would reach the back bumper.
Batman
yeah, this is the same one, look at the pics again, we pulled it out to the tailgate and pass side turnsignal
Great addition under the hood. I knew I had one kicking around in the garage from a previous GMC Sierra and I found it. I mounted mine in a different location. I'm not a firm believer of two sided tape, so my addition gets mounted/screwed to the air box. Here are some pics...If you notice closely that the screws never pierce the air box, but rather get screwed to the flashing material of the box...BTW, the light, when fully extended, reaches all the way around to the rear of the truck to the hitch...
PhanTomiZ
P.S. Tried to insert image in the text body, but didn't work...
1 - 20 of 22 Posts
