mOWWck
Project Name
How to add HMMWV shackles to your frame horns
Project Description
Add functional shackles to the holes in the frame horn that already exist for the factory tow hooks. This project is intended for users who's trucks did not come with factory tow hooks, for those that can't afford a nice shackle kit, or who want a different look with functionality for their truck. Using the frame horn as a mounting point is beneficial for towing and recovery.
Skill Level
Moderate
Make: Chevrolet
Model: Colorado
Year: 2008
Engine: 3.7L
Power windows: Yes
Sun Roof: No
Tools Needed
15mm socket
3/4" socket
3/4" wrench
Parts Needed
The shackles can come from eBay or any surplus store. The shackle hardware is not required... Just the shackles themselves are needed.
Grade 8 Hardware Recommended
(2) 1/2" x 5" bolts
(2) 1/2" nylon lock nuts
(2) 1/2" x 5/8" x 1" steel spacers
(2) 1/2 flat washers
-OPTIONAL-
Drill with 1/2" Drill Bit
Can of black spray paint
Project Time
2 hours or less
Project Cost
Shackle: ~$20
Hardware: $12.50 (Grade 8)
Extra Readings
It is strongly recommended that these following How To's be read:
Example of tow hooks purchased from eBay. These HMMWV shackles are from a M998 and may have some prior use. The hardware will not be needed.
And there you are!
mOWWck
Project Name
Project Description
Skill Level
Moderate
Make: Chevrolet
Model: Colorado
Year: 2008
Engine: 3.7L
Power windows: Yes
Sun Roof: No
Tools Needed
15mm socket
3/4" socket
3/4" wrench
Parts Needed
(2) 1/2" x 5" bolts
-OPTIONAL-
Project Time
2 hours or less
Project Cost
Shackle: ~$20
Extra Readings
- First, the grill and the bumper need to be removed. Consult the "Extra Readings" that are posted above if you do not know how to accomplish this, they are great How To's.
You should end up with something like this:
- Some 355s will have prior tow hooks with holes present, some will have holes with no tow hooks, and some may not have holes at all. Depending on your situation, you may have to drill out the frame horns. This process is explained well in the Factory Tow Hook How To.
This Colorado already had holes drilled in the frame horns, but didn't have tow hooks. So no drilling was necessary
The shackle eyes have an ID of 5/8" and use 5/8" hardware, but the frame horns have an ID of 1/2". This is why the steel spacers are required. This eliminates the need to bore out the frame horns to a larger diameter since there is a lot of extra metal that would need to be drilled through.
- Once you have drilled out the holes if necessary, install the shackles by placing the steel spacers in the eye bolts, then threading the 1/2" bolt through the frame horns and tightening the 1/2" lock nut on the opposing side. I have mine pretty snug so they do not bounce around.
- Lastly, the bumper needs to be cut so the frame horns and the shackles will be exposed. How you do it is completely up to you. You can remove the lower bumper all together or trim the required areas.
And there you are!
