burn
Project Description
C-notch your frame
Skill Level
Advanced
Make: Chevrolet
Model: Colorado
Year: 2006
Engine: 3.5L
Transmission: Auto
Power windows: No
Sun Roof: No
I started by picking up the raw material for my notch. I got 3 sheets of 1/4" thick steel. Its 6" wide X 32" long:
After taking some measurements of the frame on the Colly (along with a few educated guesses) I came up with a pattern and drew it onto the steel:
Then I got crafty with the angle-grinder and got one cut out:
Here are the measurements I used. Please note that once you start lining this up on the frame your going to have to tweak / trim them. This will just get you in the ballpark:
All 4 panels cut out:
So I'm not sure whether to consider this Phase 2 - or just the end of Phase 1... but its my thread so I'm calling it Phase 2
Anyways; tonight I got the final pieces all cut out:
Then I drilled & tapped a hole in the middle of the top plates so that I can screw the bump stops into the plate. (Once the plates are welded in; be sure to use never-seize on the bump stop threads)
And then here is the notch just placed together with the bump-stops in place:
Whelp - got home from work tonight and got right to work. Heres what we got done in about 6hrs:
Got it up on stands, removed the box. took about 30min:
got both of the bump-stop mounts cut off. OMFG what a PITA. Took about 1hr / mount:
Then after some minor trimming to the plates - traced out where they go:
And here is Chris holding the patch panels in place:
The filler panels all welded to the frame:
After grinding down the filler panels; welded the outside plate to the frame:
Then welded the inside plate to the frane:
Total time for all of the welding - about 1hr.
took about 45min to get the notch section cut out. Then about an hour to get the pieces all welded in:
And here is a shot of the piece on the inside of the frame rail. It was a PITA to weld cuz of the gas tank and all the lines along there:
Then, we fabbed up a support tab for the brake line. It was welded to the stock bump stop mount:
And here is the driver side all painted up with the new bump stop in place:
The finished passenger side:
And the notch in the bed support:
Heres a few shots of it with the box back on. Drivers side:
passenger side:
NOTE: When you are cutting / grinding / welding on your frame - make sure you cover your cab well. I used a wet bedsheet however unfortunately it was not enough. I had to spend several hours clay barring my cab to get all the fallout off of the paint. I recommend using either cardboard or even that 3M welding paper: http://solutions.3m.com/wps/portal/...CEK3_nid=GSMMTWQGDZgs8H32N3CD4SglRJXVD6KWQ6bl.
burn
Project Description
C-notch your frame
Skill Level
Advanced
Make: Chevrolet
Model: Colorado
Year: 2006
Engine: 3.5L
Transmission: Auto
Power windows: No
Sun Roof: No
passenger side:
