1 - 20 of 49 Posts
CHEEZEDOODLE
kerad11
Project Name
Change your spark plugs on a v8 355
Project Description
Changing your spark plugs
Skill Level
Moderate
Make: Chevrolet
Model: Colorado
Year: 2009
Engine: 5.3L
Power windows: yes
Sun Roof: No
Tools Needed
10mm Socket, Shorty 3/8ths Extension, 5/8ths Plug Socket, Flat Tip Screwdriver
Project Time
30min-3hrs(i take my time0
Project Cost
Cost of plugs
Stock GM Plugs Part#
First things first, you always disconnect your ground when messing with anything electrical on your truck. That's a 10mm socket on the black wire on your battery.
I disconnected the entire plug wire from the coil pack to the metal sleeve. its not easy but with patience it will wiggle out. Do not pull the plug wire to remove. You will probably break it and have to replace the full set to get one. Do not remove all of the plug wires at once. Replace each wire/plug one at a time so you don't lose track of where everything goes.
Remove the old plug.
Inspect.
Put a literal drop worth of antiseize on the threaded part of the plug. be very sparring with application. A little is almost too much.
Antiseize is needed because its an aluminum block. steel + aluminum = stuck plug down the road.
Replace the plug and be sure to seat the boots properly. You'll hear them click. I used the marks in the dust to see when they were fully seated on the coil packs.
Here's pics of plug locations.
Pass side.
Rear pass side.
Driver side.
This is the hard plug. He doesn't like you, so he hides.
All the plugs are easy to get to except the driver side front(close to the alternator). You have to remove and replace it through the wheel well. Dont cut yourself. Its easy to do. I didn't take a pic of the plug through the wheelwell cause it won't line up. Your hand barely fits. Totally messed up angle.
Shits very straight forward except that one plug.
CHEEZEDOODLE
wtf?
i put in densos? fail on the edit mr. gheywad. :kiki:
kerad11 said:
brewer15650 said:
1. part number for the plugs
2. the GAP
Do you have a picture of the " driver side plug through the wheel well and how he got to it, basically removing the inner fender.
it16#4 or 5325#4 not sure which one...but proly the 2nd one.
.4mm
You can't take a pic of the plug through the wheelwell cause it won't line up. your hand barely fits. Totally fucked up angle.
CHEEZEDOODLE
Discussion Starter · #5 ·
this huge cut on my forearm says different....
that fucking wheelwell liner is sharp as a knife on the 09 and up.
the front wheelwell liners are made of a thinner material on the newer trucks.
the back liner is still just as thick as ever tho...
CHEEZEDOODLE
Discussion Starter · #7 ·
hopefully we will make more so they can all be stuck in thier own section...
Haven't you heard? They're sourcing them from Gilette now...
Internet Troll
I have a 2 step proceedure for changing my plugs...
1. Take to service center.
2. Pick up from service center when work is done!
LOL
Nice writeup
Sorry to comment on an old post, but I was wondering would it be beneficial to replace the OEM plugs with 20K miles with DENSO Iridiums?
:th_gimmebeer:
Darth Vader
:th_gimmebeer:
I'd say no, but it wouldn't hurt anything if you did.
I say it's a waste of money. What year is your truck? I think those plugs came standard in 2008 and up??? Somebody can correct me.
But as far as swapping at 20k, I think it's a waste of money and the amount of fuel savings to be had after a $80+ expense will take forever to recoup.
CHEEZEDOODLE
Discussion Starter · #18 ·
its not WORTH it, but hardly any mods are.
you do this to upgrade to slightly better plugs.
a truck is like anything. its constantly deteriorating.
you want to reverse that stedy decline as much as possible.
but no, at that low milage, its not much good in it if your talking about the improvments impacting your wallet and recoup time.
unless you just bought it. then, always change the plugs.
CHEEZEDOODLE
Discussion Starter · #19 ·
or i might have read that wrong.
this mods worth becomes more apparent as the miles pile on.
It's a 2010 CC Z71 4x4 V8.
Gents,
Appreciate the feedback. I didn't expect that it would have been a worthwhile mod at this point. Thought I'd ask just in case the answer was, oh yeah those OEM plugs are shit get rid of them.
:th_gimmebeer:
1 - 20 of 49 Posts
