1 - 20 of 22 Posts
burn
Project Name
Check Your Pinion Angle
Project Description
When you lift / lower your truck, the angle that the drive-shaft meets the pinion can go beyond what is considered a safe angle. This can cause vibrations and eventually lead to U-joint failure or damage to your drive-shaft or other suspension parts.
Skill Level
Easy
Make: Chevrolet
Model: Colorado
Year: 2006
Tools Needed
Digital Level
Project Time
1 hour or less
Lift the rear end of the truck up off the ground by putting a jack under the differential to keep the suspension loaded. Put stands under the axle. Ideally you would do this with a hoist / pit to keep the truck level to prevent the center of gravity from shifting forward so only lift the rear as much as absolutely necessary to keep the weight transfer to a minimum - but atleast this will keep you close.
Put the truck in Neutral. Turn the drive-shaft by hand until the pinion is parallel with the ground, then attach the digital level:
Then turn the drive-shaft until it is at 0*
Then attach the digital level to the drive-shaft. Hit the reset button which will make the level assume the drive-shaft is parallel to the ground:
Then attach the digital level to the pinion:
This tells me that the pinion is at 1.8* to the drive-shaft - which is fine. Typically it should not exceed 3*. The icon in the bottom-right corner also tells me that the snout of the rear-end is facing upwards - which also is fine. No shims are required.
If you did this procedure and came out with an angle greater than 3*, subtract 3 from the angle you came up with and order that angle of shims. They go between the axle and your leaf-springs (or axle and blocks if you are lowered) to adjust the angle to get you under 3*.
Shims are available from several manufacturers including Ground Force, Belltech, Summit, etc. Here are the Belltech shims available through Summit:
1*: Belltech 4973 - Belltech Pinion Shims – SummitRacing.com
2*: Belltech 4975 - Belltech Pinion Shims – SummitRacing.com
3*: Belltech 4976 - Belltech Pinion Shims – SummitRacing.com
4*: Belltech 4977 - Belltech Pinion Shims – SummitRacing.com
6*: Belltech 4979 - Belltech Pinion Shims – SummitRacing.com
microwave
Nice write up bro. I need to check mine since I do have a slight vibration on take off. Thanks for the how to.
Well Done! :355:
Discussion Starter #6
:thumbup::thumbup::thumbup::thumbup: :thumbup::thumbup: :thumbup::thumbup::thumbup::high5: Very helpful
Discussion Starter #11
Its too hot in Texas!
Great write up Burn... I know I still need to do this.
if i have the 4 in blocks and a vib. during take off do you think i have the blocks in bakwards didnt see anything saying which way they were supposed to face but i was thinking that they were wrong they have the shim (angled top plate) on them so i think that might be it
If you have angled blocks then the smaller heigth or angle faces forward.
Discussion Starter #18
broken image links fixed
Member's Technical crew
great info, need to check mine, but don't you need to check the relation ship of the tranny tail shaft to the pinion angle? I think my tranny angle changed with the engine swap, ever since than I get a bit of a shimmy?
So I was flipping through the January 2015 issue of Car Craft magazine and saw this review of a smartphone app that will turn your phone into a angle finder.
The free app is called "Tremec Driveline Angle Finder".
By using your smartphone as a measuring device, the app will calculate each u-joint angle and provide an overall driveline operating angle with a Pass/Fail response.
This unique App will help you avoid vibration problems associated with incorrect driveshaft and u-joint working angles. The three-step graphical interface provides measurements essential for proper driveline setup, along with tips and instructions that make it possible to check angles like a pro!
The TREMEC Driveline Angle Finder App is designed to measure driveline angles on RWD vehicles equipped with a one-piece driveshaft.
Click here for User Instructions
New! TREMEC Driveline Angle Finder App
1 - 20 of 22 Posts
