1 - 11 of 11 Posts
colbyjohnson1994
Project Name
How To: Crankshaft Variation Learn Procedure
Project Description
When swapping motors, replacing crankshaft position sensors, or tuning; sometimes a P0315 code will pop up that requires you to do a Crankshaft Position Variation Learn sequence. This can be done with a Tech2 scanner, which is what I will be showing you how to do.
Skill Level
Easy
Make: GMC
Model: Canyon
Year: 2005
Engine: 3.5L
Tools Needed
GM Tech2 Scanner
Project Time
5 minutes
Project Cost
Renting or borrowing a Tech2 Scanner
The steps shown in this video will effectively remove the P0315 code that may occur when swapping motors, tuning, or replacing the crankshaft position sensor.
Yay, no codes!
Sponsored by SuperModulation Tuning Services
well done Colby
Colby, I got lucky and I got the original PCM from James that already had my info flashed on it, so there was no re-learn required.....thankfully.
But I'm waiting on the ABS DTC thing your working on. Come to find out the ABS/Brake issue kind of fixes itself when you remember to plug the ABS module back in; I never plugged mine back in when I did the 5 spd swap. I had unplugged it to get the clutch master cylinder installed......... there were a few F' Bombs involved
Discussion Starter · #9 ·
Those kinds of things happen we tear lots of things apart lol.
Yea, I'm planning on doing a few scenarios with the Tech2 to really produce a good informational video on using the Tech2 to diagnose ABS.
I would really like to simulate the ABS sensor gap not being set right (like the most common reason for the front ABS sensor's not working), but I don't want to screw up my own to do it :lmao:
Maybe I'll give mine a love tap with a rubber detail mallet and see what happens :hide:
BUT I'll wait to scan the system first
Really makes me want to buy a Tech2 now...... I'm getting ready to buy an all in 1 for BMW since I do so much work on them. Their hand held will handle CELs, ABS and SRS(airbags)
Discussion Starter · #11 ·
They expensive......lol
1 - 11 of 11 Posts
