SuperModulation & 1BADI5
Project Name
HOW-TO Diagnose and Repair "ABS FAULT"
Project Description
Diagnose and repair common ABS failures (ABS FAULT).
Skill Level
Easy
Make: GMC
Model: Canyon
Year: 2006
Engine: 3.5L
Power windows: Yes
Sun Roof: No
Tools Needed
Medium flat head screw driver
Hammer, NOT BFH!
TECH II or ABS Diagnostic tool
Project Time
10 minutes or less
Project Cost if needed
ABS and Speed Wheel Sensors
Passenger side (RH) Front wheel sensor, GM# 15176998, Price $40.00
Driver side (LH) Front wheels sensor, GM# 15176997, Price $40.00
ABS FAULT Troubleshooting
a. The first thing you should do is check the fuses located in the fuse box under your hood.
b. Inspect both inner wheel hubs for any debris, damage or wheel hub bearing failures.
c. Check both wheel sensors wiring harness and connector located behind the fender.
d. Use ABS diagnostics tools to determine which wheel sensor is malfunctioning.
e. ALL above fails, seek professional help by a certified mechanic.
CAUTION: Always use caution when working under your vehicle. Always park on a level ground, Chuck wheels, Vehicle in PARK, Emergency brake ON and ignition OFF (Keys removed from vehicle).
ABS/SPEED Wheel Sensor location. Front view, turn wheel outward to access sensor.
Check for debris, dirt or any lodged items in between CV/bearing and wheel sensor housing.
Inspect ABS/SPEED sensor wire harness for any cuts or wire exposure.
Check to see if the harness is loose and not obstructed.
Inspect ABS/SPEED electrical connector located behind fender.
The only way to troubleshoot your ABS electronics is with either a TECH II (Dealer) or a specific ABS scan tool.
The standard ODBII scanner (SCANGAUGE/HPtuner) will not be able to read or clear the log tables.
If the log tables are not cleared, In some states you may fail vehicle state inspection.
Wheel Sensor Alignment
One of the most common ABS failures is also caused by, misaligned or improperly installed wheel sensors.
The sensor is a magnetic pickup type that uses a field effect transistor. This sensor type is considered a low signal pulse and is air gap dependent.
The farther the air gap the lower the signal and visa versa the closer the air gap the higher the pulse signal. The distance between the wheel sensor and the magnet should be about a business card thickness.
Because of the design there is no practical way of calibrating it other than by placing a medium size flat head screw driver next to the sensor, with several taps with a hammer pushing the sensor inward will now bring that gap closer, ie increasing the sensor signal. Do a little at a time then go for a test drive around the block.
The ABS controller resets it's self ever time you shut your truck off. Once you see the DIC clear and no more ABS FAULT, you have the correct air gap.
CAUTION: To much and it will brake the sensor.
Set screw driver blade in between sensor and rim. Tap once or twice and go for a test drive!
Hope this helps and thanks for supporting our 355 community!
James:supermod2:
Project Name
Project Description
Skill Level
Easy
Make: GMC
Model: Canyon
Year: 2006
Engine: 3.5L
Power windows: Yes
Sun Roof: No
Tools Needed
Hammer, NOT BFH!
Project Time
10 minutes or less
Diagnostic Tools1BADI5 - Jeremy
Damaged ABS/SPEED wheel Sensors:
After damaging one of my own wheel speed sensors I gained some insight. The cause of the sensor failure about 75% of the time per GM techs is the highlighted area on the picture below. (I damaged mine while swapping out rotors- going to the PowerSlots. I mishandled while pulling the hub out and not having an extra set of hand to feed the ABS wheel speed sensor harness through the spindle)
The connection from the actual sensor to the harness is very delicate copper coiled wire(encased). The Service Manager informed me that the Colorado's, Silverados, Tahoes, Suburbans and their GMC brothers(2003-2006) all share this design. He said its a very poor design that supposed to be redesigned because of its sensitivity. He then followed on to explain that the techs working on them have had a 50/50 ratio of having them break or good bad while servicing these vehicles; ie working/replacing axle shafts, hubs and other associated components in that region.
So the point for that long winded explanation is to reiterate how careful you need to be with that harness/sensor. It was not even until 2006-07 where you could only buy the sensor from GM; prior to that you had buy the whole hub for $440 bucks(per side) in Dec 2005. Well do to the engineering issue, GM elected to start selling the sensors as a separate part numbers(part numbers are provided above).
James:supermod2:
