This will be the easiest mod you ever do for nothing! ( update, 11/22/11 this mod is still working with out a problem!)
Hid safe! its actually better for them!
..........If you have factory fogs they will not work without doing the fog lamp relay mod to keep them all on........
I know there are other ways of doing this mod internally but this works just the same.
1. Pull your dimmer (Beam Select) Relay
2. On the bottom of the relay ther are five prongs with numbers. You want to take the two prongs numbered 30 and 87a. Cut a jumper wire and solder the jumper to each prong. Then cover with electrical tape.
3. Put the relay back in back in and turn on your high beams.
Before:
After:
