How do you do the fog lamp relay
If it provides a common ground couldn't you just as well ground the low beam light to the chasse to get the same effect? Maybe this would be a little bit cleaner mod considering you wouldn't have to tamper with the relay.negative. No effect on electrical system. Our lights are on 2 different systems. This just provides a common ground.
Isn't it also possible to ground the low beams as well? I've seen this done on silverado's but never a colorado, I wasn't sure, but I think all the relay does is cut the ground to the low beam when the high beam is turned on. And if so, has anyone tired this method? I did the relay cross over for my bi-xenon projectors but I am having trouble now.. Please Help! lol
This most definitely works. After doing the same mod on my Tahoe, I tried it on the Colorado and it worked like a charm. Just ground the lowbeam harness to the battery/frame on the drivers side, and you're good to go. I can pull it back apart and provide pics if necessary.If it provides a common ground couldn't you just as well ground the low beam light to the chasse to get the same effect? Maybe this would be a little bit cleaner mod considering you wouldn't have to tamper with the relay.
Would you mind posting pics of your install and where/how you grounded the low beam harness? I'm interested in replicating your efforts.This most definitely works. After doing the same mod on my Tahoe, I tried it on the Colorado and it worked like a charm. Just ground the lowbeam harness to the battery/frame on the drivers side, and you're good to go. I can pull it back apart and provide pics if necessary.
So, this is what the Mr. Taillight kit provides is a relay with the connection already made?It wont cause any harm.
There are guys who have done this well before the Mr. Taillight kit came out for our trucks (which was quite a long time ago -- a couple years if not more) and still have it functioning today, without any problems.
If your low beams and fogs have the right bulb placing and correct aiming it should work in heavy fog. The problem most people run into is the placement on the LED bulb is different from the placement of the filament on the stock bulb thus creating a wash.WOW, now I'm finally motivated to upgrade the headlights. Owned mine since '04 but the lighting remains stock. After reading all 24 pages it seems to me the best plan would be to combine this simple modification with the installation of LEDS. The reduced wattage requirement of the LEDs mean's that the 10 amp fuses are adequate and the relay wouldn't stressed. I plan to install the jumper wire a little differently and will provide a photo when its done.
I use lot's of crooked rural roads and actually being able to see the deer, raccoons, owls, cows, and other night creatures will be great.
Anyone have any experience using high output low beams in heavy fog? Is more light worse? I know high beams become useless.
