1 - 20 of 29 Posts
You've waited, now here it is, my exclusive E brake mod write-up. whoever did that is a dick. lol
greg larkins
Project Name
How-to: Emergency Brake cable re-routing
Project Description
Rerouting the Emergency Brake Cables for a cleaner look
Skill Level
Beginner
Make: Chevrolet
Model: Colorado
Year: 2007
Engine: 2.9L
Power windows: Y
Sun Roof: N
Tools Needed
Vice Grips, Zip Ties, 10mm Wrench, drill, nut driver, self tapping screws
Project Time
~30 mintues
Project Cost
<$5
Here We Go...
Step 1, after securing the vehicle and lifting it off the ground, use the vice-grips and clamp down on e brake line where it is square shaped under the driver door before it T's off. Using your 10mm wrench, untighten the line. the two lines that T off here remove simply by slacking the line enough to where the cables can be pulled free of their housing. the two Tee'd lines can now be pulled out the back end of their housing.
Step 2, Find the best route for the lines and test for proper fit. the lines can bee a bit long, but can't be too short to reach back to the block where they Tee'd off of. here is how i ran each side.
Passenger side
Body mount is rear cab mount on driver side
body mount is rear cab mount on driver side
Driver side
The driver side is pretty self explanatory. after you pre-run your lines, secure line with zip ties, and cable clamps. i only had to use cable clamps to hold the line above the exhaust, the rest of it was zip tied.
5cylinder and Tire slayer
is there anyway you can post the pics IN the post instead of with links?
and the pics are HUUUGE in the links..
:shrug:
might help some people..
yeah but its gonna slow most peoples down and a lot will have to scroll to see the pics :shrug:
nice write up tho!! :high5:
Member's Technical crew
Is this to get rid of the ugly e-brake dropping down and crossing over the frame? Any finished pics of the drive-ride frame rail E-brake routing? Also pics are so..big! I wish my screen was better! It's hard for me to get an overall "picture".
I'm definitely Doing this when I swap My V8 back in, give it a nice clean look!
Factory Fresh
I had my truck up an rack about a week ago and looked it over. its pretty straight forward once you get down there.
I was going to take a look at doing this over the weekend, but I can not see any of the pictures on this thread. Anyone have any pictures of how the cables are rerouted or anything to help with this project?
anyone have updated pics of this?
1 - 20 of 29 Posts
