1 - 20 of 54 Posts
Silver08Colorado
Project Name
Grind your CCFL light shield, add a 194 LED bulb and install HIDs
Project Description
How To Grind down the light shield on your CCFL to give more low beam projection
Skill Level
Moderate
Make: Chevrolet
Model: Colorado
Year: 2008
Engine: 3.7L
Power windows: Yes
Sun Roof: No
Tools Needed
Big ass flat head screw driver (for prying the grill off)
Philips head screw driver
Ratchet with 10 mm socket
Bench grinder
Project Time
1 hour or less
Project Cost
CCFLs - $165 (on Ebay)
2 Blue 5 LED 194 replacement bulbs - $3
35W 8K H7 DDM tuning HIDs - $45 (approx)
Effort and cost of tools
REMOVING YOUR CCFL
1) Using the Grill Removal How-To, remove the grill and DRLs from your truck
2) Use your ratchet to remove these two screws from your CCFLs
3) Place your CCFL face down to get to the back section where you put the bulbs in
GRINDING YOUR LIGHT SHIELD
1) Locate the adjuster bar on your CCFL, it will be facing towards the top of the CCFL
2) Turn the adjuster bar so it's now facing down, this will allow you easier access to the internal parts when both taking apart and reinstalling.
3) Remove these 3 screws
4) Carefully maneuver out of the housing, the bulb mounting base and the light shield:
A)bulb mounting base:
B)light shield:
5) This is a very thin piece of metal, so when grinding it down, be very careful. (Unfortunately I did not get a before picture of the shield when I did this write-up)
6) Once you have completed the grinding to your satisfaction, reverse these steps to reinstall
7) Use the adjuster bar to raise or lower the aim of your low beam.
Notice the difference (before):
As an added bonus, I'm also including how to add HIDs and change the yellow 194 bulbs:
ADDING HIDS
1) I found it easier to actually "tuck" my ballasts away inside the inner part of the CCFL
2) When it comes to HIDs, everyone "hopefully" knows to reverse your wiring. Well I did that on the internal part of the CCFL so you can just re-snap the connections together normally:
**Note the colors of the wires: Blue CCFL positive to black HID negative and Black CCFL negative to Red HID postive**
3) Close it back up and then onto the hi beams for the 194 bulb change
CHANGING 194 BULBS
1) In the hi beam section, locate this bulb:
2) Twist to the left, pull it out and put in new bulb:
truck built on Saturday..
Help full!!!!!
Nice job on the write up! I especially like the LED swap for the 194's! Makes me wanna put mah ccfls back in, esp since my stockers are gettin all foggy inside lol
Great job Matt!
Thanks for the contribution!
Texas Yoda!!!!
Discussion Starter · #9 ·
Thanks!
Maybe u can use this in there.
Thanks for the picture :thumbup:
why wouldn't they just make that deflector straight???
it looks so retarded specially on the walls the stupid incline on the deflector/shield :gd:
Because they are trying to prevent us from blinding other drivers which I see is a good idea. However, when you put your lights on and your low beams don't shine further than your fogs, well then that is why my how-to got created.
Discussion Starter · #11 ·
it was designed so it allows you to throw more general light off to the right side further or higher up.
Unfortunately, it still wasn't high enough.
Texas Yoda!!!!
1 - 20 of 54 Posts
