1 - 9 of 9 Posts
switzxx20
Project Name
How-To:
Project Description
Hook up AVIC-D3 Navigation and Reverse Wire to use all functions associated with the AVIC-D3 and D2.
Skill Level
Moderate
Make: Chevrolet
Model: Colorado
Year: 2006
Engine: 2.8L
Power windows: No
Sun Roof: No
Tools Needed
Wire Strippers
Wire Cutters
Wire Crimps
Wire Butt Connectors
Project Time
Less that one hour.
Project Cost
Free
**It has been confirmed that this also works with the AVIC-D2 models**
I know the answer has been already discussed, but I wanted to make an easy shortcut for those having problems hooking up the pink wire.
I've had the pink wire hooked up at the PCM, then disconnected, and now finally properly connected.
Just to be safe, I disconnected the negative battery terminal before doing this.
Step 1.) Grab the pink wire and run in it through the driver side firewall, or run in through the passenger firewall like I did.
Step 2.) Next, locate the wiring near the passenger fender. You should see a tan wire and green wire running side by side. It's deep in there so hopefully you've got long arms or a chair ready!
Step 3.) Get a tap-in and run the tan wire through. Now shorten the pink wire and run it through right next to the tan wire.
Step 4.) Make sure the tap-in snaps to ensure it has successfully stripped the wires enough to make a connection.
Step 5.) Start your truck up and make sure to reset the AVIC-D3 by pressing the tiny button next to the disc vacuum.
Step 6.) Go to the NAV menu, SETTINGS, and then HARDWARE INFO. Then go to 3D CALIBRATION and start driving. Try going up a little hill to make sure it's reading correctly.
Step 7.) You should be in 3D Hybrid mode now and if you did everything correctly, your DVD playback and Navigation menu should still work fine while driving.
How To: hook-up the reverse wire that works with the backup camera feature.
Step 1.) On the driver's side fender under the battery, there is a plug that has several different colored wires running from it.
Step 2.) There are 3 green wires going into it, you want the lightest green one. (the other two are more of a dark green/forest green color).
Step 3.) Use a tap-in the exact same way as the pink/navigation wire went into the speed sensor wire. So in this case it would be the tapping into the lightest green wire with the purple/white wire.
Discussion Starter #4
Re: How-To: Hook up AVIC-D3 Navigation Wire
I bet you had to use a step ladder to reach that tan wire 'cause the chair wasn't tall enough for you. :kiki2:
Eat my ass ****, I'm sure your gay ass could of reached it :ghey:
PS That front license plate looks sick, dildo :fugrin:
Discussion Starter #6
It's okay, I like my arms with a little hair on them anyway :thumbup2:
Not really, Alex got the same ticket two nights in a row hahaha
For no front plate??
Discussion Starter #8
Yeah! Isn't that weird?
He got pulled over the first time, and the next night he walked up to his car in front of his gf's house and there was an envelope waiting for him :econo:
Dam that sucks i got one like that from a metermaid, i just paid it oh well 25 bucks, better than drillin holes in my bumpa!
1 - 9 of 9 Posts
