1 - 12 of 12 Posts
rshadd
Project Name
How To make your own foam cannon
Project Description
How To Make a Foam Cannon
Skill Level
Easy
Make: Chevrolet
Model: Colorado
Year: 2005
Engine: 3.5L
Power windows: No
Sun Roof: No
Tools Needed
  • Line Wrenches (for the brass)
Parts Needed
  • MTM Hydro Long-Range Detergent Foamer Attachment (Part # 14.0263) $42.99
  • Pressure Washer Plated Steel Nipple — 3/8in. Male Inlet, 4000 PSI (313106) $5.98 (you need two)
  • Brass Pressure Washer Quick Coupler — 3/8in. Inlet Size, 4000 PSI (313108) $6.99
  • Pressure Washer Trigger Spray Gun — 4000 PSI, 8 GPM (Part #2227) $14.99
  • Pressure Washer Nipple — 1/4in. Fitting, 4000 PSI (2296) $2.99
  • Thread Sealant (Loctite 545) $1.75 for 0.5. (Teflon® tape works too, and is alot easier to find)
Project Time
1 hour or less
Project Cost
$80
What is a foam cannon?
Cover your truck in a goobs of thick foam quickly with a Foam Cannon! A foam cannon (or lance) works with a pressure washer to produce a thick, clinging foam.
The benefit of using a foam lance to deliver the soap to the vehicle is that it doesn't require you to touch the vehicle, which could rub dirt against the paint. The Foam Cannon sprays the vehicle with a thick coat of soap to loosen and lubricate dirt. On dusty or lightly dirty vehicles, you may not even need to hand-wash. The Foam Cannon HP minimizes the amount of hands-on contact with the vehicle, which can minimize wash-induced swirls. Plus, a Foam Cannon is a just plain fun!
Do I need one?
Heck no.
Do I want one?
Of course you do.
These go for around $120 on most automotive detail sites but you can make you own easily with a little bit of effort.
Here's a video of the foam lance in action... Put's out goobs of thick foam. This thing makes a foam gun look like a joke.
http://www.youtube.com/watch?v=tXxhsKYXYZc
Very nice.
I have a cheap little plastic one, but your version is "ferocious", it reminds me of airport firefighting equipment.
That's pretty cool. I have a foamer that came with my pressure washer. Never really used it on the truck. Also do you wash you truck in the garage or was that just for testing.
Do you smell that?
Jeff washes his truck in the garage like a boss!
Your truck looked clean already lol
I think he said he built the gagarge with a slight grade to drain out the water. Its pretty cool
Great write up
1 - 12 of 12 Posts
