21 - 34 of 34 Posts
Discussion Starter #22
Nope. Just take the 2 10mm bolts to unbolt the condenser from the radiator. Then I used a screw driver to help it out of the holder on the bottom. Just pop the condenser out and it'll sit there while you swap radiators.
Is the H3 3.7 radiator also a 2 core 13qt set up?
Where I have a 5 speed now I was looking at going with the H3 MA5 radiator
Discussion Starter #24
I don't have a clue
Member's Technical crew
I.ve wondered this two Jeremy, and some how I think that it is? Let me know if you find out?
I don't want to change it unless my 04 rad pops... can you believe it still has the stock GM 04 rad?? no upper right or upper left leak? Its also been in and out of the truck Twice..
Hmm... For some reason I thought there was alot more to this swap than that...
Guess I'm gonna have to do this now also.
Anyone from VA that's done this willing to help me install mine, an efan, and a thermostat spacer.
@Kpooch, I've not done the rad swap, but I have the SFAN4500 and only live an hour away. Going to Orlando this weekend, you in a hurry?
Awesome that would be nice. I'm not in a huge hurry, just want to get it done before Thanksgiving. I'm free whenever.
Sorry to bring up this old thread. I did a search and could not find what I was looking for. Anyways my 2006 i5 4WD Crew Cab Colorado is leaking from the radiator. I would like to put in the V8 radiator as on the Highway in SoCal it has always run hotter than I would like which is at the 3rd large line on the gauge which I believe corresponds with 220 if I am guessing right when comparing it to the typical GM temp gauge that actually has numbers. Anyways 220°F at highways speeds without towing anything it too high in my opinion, and won't be cured with an electric fan. I would hate to find out what would have happened if I was towing something... I plan to use it to tow horses one day.
Ok so my question is do I really need a V8 shroud or will the i5 Shroud fit. What mods would be needed to the i5 shroud? Since its leaking I want everything prepared as I will need to fix this quick.
Thanks
Ok so my question is do I really need a V8 Shroud or will the V6 Shroud fit. What mods would be needed to the V6 shroud? Since its leaking I want everything prepared as I will need to fix this quick.
Thanks
V6??? Do you mean inline 5?
2004-2012 never came with a 6 cyl
Yes sorry, the i5. Does the i5 radiator shround fit the mechanical fan when you install the V8 radiator?
341466
Left is a 3.7 I5 radiator, right is a 5.3 V8. just 5" wider overall and slightly thicker. It will probably require some modification but I would say should work.
21 - 34 of 34 Posts
