1 - 18 of 18 Posts
Administrator
Supermodulation
Project Name
How To: Install AirLift Bag Spacers on a Lifted Z71 with AAL
Project Description
This write-up is an upgrade to your exiting AirLift installation.
Add 1 1/2" Spacer Blocks to your AirLift Bags.
Skill Level
Moderate
Modified GMT355:
Make: GMC
Model: Canyon SLE 4WD
Year: 2006
Engine: 3.5L
Power windows: Yes
Sun Roof: No
Tool Needed
9/16 socket
9/16 open end wrench
Large Philip's head screw driver
Parts Needed
Add-A-Leaf: Skyjacker AAL RCC25
Shocks: Skyjacker H7084
Air Bags: AirLift Ride Control # 59539
Compressor: AirLift SureSet with Digital Controller
Hardware:
Spacer Blocks: 2 x 3 1/2" x 2 1/2" x Thickness 3/4" for a total of 1 1/2" spacer block.
Bolts: 2, Modified original 1/2 bolt by welding on 1 1/2" for a total of 2" in length.
Project Time
1 Hour
Project Cost
$10.00
Tools:
Original 1/2" x 7/8 " Taper Flat Head Bolts:
Extended 2" bolt:
Spacer Blocks: 2 x Length - 3 1/2" x Width - 2 1/2" x Thickness 3/4".
De-pressurize air bags by disconnecting air lines:
Remove air bag bottom shackle bracket and install spacer with longer bolt.
Note: Do NOT over tighten bolt!
Make sure when installing the spacers to keep the shackle bracket parallel to the shackle.
This will prevent the air bags from twisting when you inflate them.
with shackles and a aal this that will be to much of a space for these bags?
anyone know?
im gonna grab the suspensionmaxx shackles and set them at 2"
ok sweet :) ill just have to make the blocks a little bigger then those then right?
Administrator
Discussion Starter · #8 ·
The block size isn't an issue but the center flat head bolt is. Buy a slightly longer bolt and grind it down to size.
ok sounds good :thumbup:
hey james, did u weld those blocks or buy them?
Those are awesome! This mod is perfect for you:thumbup:
Hi Supermod! I just bought Skidz off eBay the other day. Thanks for your follow-up call. Left you a message about the oil change facilitation valve in case you are selling those too.
But my question here concerns the correct spacers for this Airlift airbag mod, except I'm doing the SM 2" shackles, no AAL. I contacted the fellow you replied to here, but he hasn't done his bags yet so he hadn't fabbed any spacers. My shackles and bags are here, I just need the exact spacing material (or specs) for the 2" shackle setting (around a inch, but.....?) Do you happen to know the typical distance for the Z71 crew 2008 that would work? I could just put the truck up and measure, but I'm going to hire the work out to my mechanic, but would prefer to just hand him the right parts. Also, what bolt length? I can buy long ones and cut them down to work. I just can't do the heavier work right now.
Can't wait to get my Skidz on!
Donovan in Oxnard.
just got my airbags in the mail today, and wanted to check in with people who have done this mod.
anyone have any issues with overextending the bags while flexing the rear suspension? i'd like to know before making my spacer blocks.
also wondering if anyone has plumbed the lines together with a valve, to allow air to pass between the bags for articulation when desired, or to close of air passage for normal driving.
thanks
Just got my Air Lift and spacer kit on the FedEx from Summit yesterday and tried to install it last night.
Just a word of warning to people buying the Air Lift and the spacer kit - the spacer kit does not come with the correct hardware to work with the Air Lift. It's missing the 1/2" x ~3" taper head bolt required to work (the same thing that Supermod fabbed up) The bolt holes in the spacers aren't even 1/2".
Spacer kit (missing two big bolts to work with the kit below)
Air Lift 52130 - Air Lift Air Bag Helper Spring Spacers - Overview - SummitRacing.com
The Air Lift:
Air Lift 59539 - Air Lift Ride Control Kits - Overview - SummitRacing.com
Administrator
Discussion Starter · #17 ·
The Air Lift:
At the time they didn't offer a spacer kit but good to know they do now.
Thanks for the heads up!:thumbup:
So i just did my Airlift on an AAL lifted z71. I got the plastic two inch spacers. For those of you wondering where to get a 1/2-13 x 3 inch tapered head, Grainger had them in stock. I had to buy 5 because they sell everything as a pack. Cost me 22 bucks I think, but for 5 stainless specialty bolts I didn't think that was too bad. if you don't have the option to fabricate I think that's a reasonable alternative. I believe Fastenal had them as well.
1 - 18 of 18 Posts
