1 - 20 of 24 Posts
X
Discussion Starter #1 (Edited by Moderator)
xtreme07
Project Name
How To: Install Belltech Steet Performance Shocks
Project Description
Aftermarket Replacement of the rear leaf spring shock.
Skill Level
Moderate
Make: Chevrolet
Model: Colorado
Year: 2007
Engine: 3.7L
Power windows: Yes
Sun Roof: No
Tool Needed
10mm socket
21mm socket
extensions
ratchet
Project Time
1 hour
Project Cost
$59 per each Stylin' Trucks Truck Accessories -- pickup truck, SUV, and custom truck accessories
Start off by parking the truck on level ground and jack up one side of the truck and put a jack stand under it.
There are 3 bolts to take off the old shock. the two on top are 10mm and you will need a very big extension to reach these. The big one on the bottom is a 21mm.
Unbolt the stock shock and put the new shock in.
You will need to bolt up the 2 top bolts first then the bottom one. you will have to remove the jackstand and slowly let the truck down to bolt up the bottom. the shock is about 2 inches shorter than stock..
Continues steps on the other side.
Installed
X
Re: How-To: Install Belltech Street Performance Shocks
ill have a how-to on the coilovers soon too. keep a look out.. :355:
why even bother jacking the truck up at all? still good info tho
Nice :)
I need some drop shocks sooner or later. They look much better anyhow!!!
X
i cant get under it if i dont.. haha
thanks for the compliments everyone:salute:
Those are nice. Are those the adjustable dampening ones? I like how they're shorter but doesn't make a difference on mine since i got blocks so stock sized ones are ok too.
X
Discussion Starter #10
no dampening adjustment. my pockets arent deep enough lol
So would these be a nice way to go to get a stiffer ride in the rear, or could you go with a cheaper drop shock that's not as short, like the Nitro Shocks since you don't necessarily need a shorter shock in the rear?
And what do you think about the new ride quality Xtreme?
Drop shocks wont do much for you unless you're running drop leafs.
They will stiffen up the ride though.
Although the ones with dampening adjustment can if you're riding really low.
That's all I'm looking for here, a stiffer ride. If I can achieve that with the cheaper Nitro Shocks as opposed to these more expensive ones, then I'll go that route for obvious reasons.
Josh, if all you want is a stiffer rear then yea go with a stiffer rear shock. Im still runnin my stockers and i know they're crap but i don't have any money right now to get some better ones. But DB has the DJM ones and says they're really stiff. I helped him install them and compared to stock holy crap are they stiff. Im sure the belltech nitros are the same. Otherwise any S10 rear shock will work too.
So basically flip a coin between Toxics and Nitro's? hahaha
1 - 20 of 24 Posts
