rangerbob
Project Name
How-To: Install Electric Fan
Project Description
Please Update This
Skill Level
Moderate
Make: GMC
Model: Canyon Z71
Year: 2005
Engine: 5cly
Power windows: Yes
Sun Roof: No
Tool Needed
Needs Updated
Project Time
Needs Updated
Project Cost
Needs Updated
Flex-A-Lite M150 instructions here [pdf warning]
0. Make sure you truck is cool. The radiator gets mighty warm kids.....
1. Remove the little metal clips that hold the fan shroud together. There should be 4 or 5 of them - all in plain sight. Use needle nose pliers.
2. I used a set of channel-lock pliers to loosen the nut that mounts the fan assembly to the pulley. This nut is a hair too big for my 12" crescent hammer ( crescent wrench for those who have not discovered the amazing magical hammer property ). You may need to jam a pulley to keep the belt from turning - use a screwdriver or some such. You guys are smart enough to figure out how. I hope.
3. Once you have the fan nut loosened you should be able to remove it with your fingers and then remove the shroud. You may have to remove the top portion of the shroud first. There are three pieces that make up the shroud.
4. Thread the rods into the fan - Jeremy (1badI5) trimmed these down for me as they were a little long. I recommend spinning a set of nuts onto each rod BEFORE CUTTING so that you can use the nuts to chase the threads in case they get a little mangled while cutting. A Dremel worked well here for trimming. ALSO, mark the rods WHILE HOLDING THE FAN IN PLACE to ensure that you have enough left over for adjustment.
5. The fan will mount sideways - I mounted it with the control box pointing towards the passenger side. In order to mount it properly you need to have the following threaded onto the rods:
Now for the wiring:
The Black Magic M-150 from Flex-a-Lite has a couple of options:
* You can use a switch to keep the fan from turning on.
* You can use a switch to turn on the fan whenever you want.
* There is a hook-up that turns the fan on when the AC compressor cycles.
I currently have mine wired without any switches. I'll be adding the switches in the future. MAKE SURE TO USE LOOMING TO PROTECT THE WIRES.
1. Run the ground wire to a suitable ground point - I used airbox mounting point like I have for my high-beam mod relay.
2. Run the AC compressor wire - you will need to trim some of the looming off of the AC compressor control wire in order to use the wiretap. PLEASE BE CAREFUL - I will laugh at you if you cut the wire while trimming the looming. I ran the wire over the top of the radiator ( pictures will show this ).
3. Run the power line from the battery using supplied fuse holder. Again I ran this over the top of the radiator.
4. The control box has two posts that need power if you want the fan to run. One option is to hook the second ( control ) power feed to a switched power source. This will prevent the fan from running when the truck is off.
I choose to hook it to an always live source ( same feed as battery ) so that the fan will run regardless of the ignition state. I did this by rigging a split off of the power feed coming from the battery ( picture will show ).
If you want to control this - put this onto a switch - then you don't have to worry about the fan coming on and taking your fingers off. Also good for us offroaders and water crossings when it's silly for the fan to turn on.
5. Take the temperature probe and GENTLY wiggle it between the fins. If you pick the right spot it will wiggle between the fins of the AC condensor and slide all the way flush like it shows in the instructions. I didn't bother with the little plastic cap they give you. The location I choose is near the upper ( read hot water input ) radiator hose ( picture will show ).
6. Make sure that the knob is turned all the way clockwise.
Now the fun begins. Assuming you have it all wired up correctly you can now start your truck and let it get up to temperature. Once your truck reaches a temperature ABOVE NORMAL where you'd like it to start cooling turn the knob counter-clockwise until the fan kicks on.
You may have to adjust this until it turns on at the point you desire.
WARNING: Make sure you pay attention when adjusting this knob. I have a nice new scar from bumping my knuckle into the power steering pulley while it was running. :lol:
Let me know if you have any questions or want pictures of a specific part of the install. Pictures as soon as I get them off of my camera! I noticed a gain of around 1 to 1.1 mpg from this mod alone. The truck also warms up to operating temperature about 1-2 minutes quicker.
rangerbob
Project Name
Project Description
Please Update This
Skill Level
Moderate
Make: GMC
Model: Canyon Z71
Year: 2005
Engine: 5cly
Power windows: Yes
Sun Roof: No
Tool Needed
Needs Updated
Project Time
Needs Updated
Project Cost
Needs Updated
6. Adjust the nuts so that the plate firmly grips the side of the radiator. Jeremy and I held the fan pressed against the radiator while tightening it all down. Hasn't moved at all.In this order - said:Nut, washer, plate, washer, nut
Now for the wiring:
