comdrop9073
Project Name
How-To: Install TPMS Sensors and Reset TPM Systemn
Project Description
Learn the installation procedure of Tire Pressure Monitoring System (TPMS) sensors, and how to reset the TPMS.
Skill Level
Easy
Make: Chevrolet
Model: Colorado
Year: 2009
Engine: 3.7L
Power windows: Yes
Sun Roof: No
Tools Needed
Your Sensors may require different tools. Check before attempting installation.
14mm Openend Wrench
13mm Deep Socket
12mm Deep Socket (AC Delco)
Torx T-25
Clean, lint free Towel or Rag
Project Time
1 hour or less
Project Cost
Cost of TPM sensors.
DORMAN Part #: 974008 $33.97ea.
AC Delco Part #: 20927604 $42.23ea.
AC Delco Valve Kit : 19117462 $5.08ea. Will require the valve stem Nut and core kit if installing on a new wheel (if replacing a defective unit you will not need this kit)
RockAuto Parts Catalog
Installation of Sensors
With the tire removed, clean the valve stem hole with a Lint free cloth to ensure there is nothing that will compromise the seal between the valve stem the wheel.
Also clean the back side of the wheel.
Check the valve stem seal for any cracks or imperfections. Also clean the seal.
Sequence of sensor installation.
Insert the valve stem into the wheel from the backside (Inside). Make sure you have room for the wrench to clear the wheel.
From the face of the wheel, remove the valve stem cap and install the washer included with the sensor over the valve stem.
Install the included Valve Stem nut and hand tighten.
With your open end wrench hold the back side of the sensor still. Use a deep socket and tighten the valve stem nut to your sensors required torque. Notice the seal will expand against the back side of the wheel (Doorman Torque 35 lb-in AC Delco: 62 lb in). Be careful not to scratch the face of your wheel with the socket.
Hand tighten the valve stem cap when complete.
Place the screw through the slit in the sensor and start to thread the screw into the valve stem. Make sure the sensor is as flush to the wheel as it can be. You do not want it to stick up from the wheel
Note: Not all TPMS will have this fastener, ACdelco Sensor and valve stem are one unit.
Tighten the sensor to the required torque. (Doorman is 35lb-in)
TPMS Sensor Matching Process
Each TPMS sensor has a unique identification code. Any time you replace one or more of the TPMS sensors or rotate your vehicle’s tires, the identification codes need to be matched to the new tire/wheel position.
The sensors are matched to the tire/wheel positions in the following order: driver side front tire, passenger side front tire, passenger side rear tire, and driver side rear tire using a TPMS diagnostic tool. See your dealer/retailer for service.
The TPMS sensors can also be matched to each tire/wheel position by increasing or decreasing the tire’s air pressure. If increasing the tire’s air pressure, do not exceed the maximum inflation pressure indicated on the tire’s sidewall. To let air-pressure out of a tire you can use the pointed end of the valve cap, a pencil-style air pressure gage, or a key.
You have one minute to match the first tire/wheel position, and five minutes overall, to match all four tire/wheel positions. If it takes longer than one minute, to match the first tire and wheel, or more than five minutes to match all four tire and wheel positions, the matching process stops and you need to start over.
The TPMS sensor matching procedure is outlined below:
As an alternative, others have successfully used the following method which is easiler and seems to work equally as well:
comdrop9073
Project Name
Project Description
Skill Level
Easy
Make: Chevrolet
Model: Colorado
Year: 2009
Engine: 3.7L
Power windows: Yes
Sun Roof: No
Tools Needed
14mm Openend Wrench
13mm Deep Socket
Torx T-25
Project Time
1 hour or less
Project Cost
- Set the parking brake.
- Turn the ignition switch to ON/RUN with the engine off.
- Turn the exterior lamp switch from AUTO to OFF four times within three seconds. A double horn chirp will sound and the TPMS low tire warning light starts flashing. The double horn chirp and flashing TPMS warning light indicates the TPMS matching process has started. The TPMS warning light should continue flashing throughout the matching procedure. The LOW TIRE message displays on the Driver Information Center (DIC).
- Start with the driver side front tire.
- Remove the valve cap from the valve cap stem. Activate the TPMS sensor by increasing or decreasing the tire’s air pressure for 10 seconds, then stop and listen for a single horn chirp. The single horn chirp should sound within 15 seconds, confirming that the sensor identification code has been matched to this tire and wheel position. If you do not hear the confirming single horn chirp, turn the ignition switch to LOCK and start over beginning with Step 2.
- Proceed to the passenger side front tire, and repeat the procedure in Step 5.
- Proceed to the passenger side rear tire, and repeat the procedure in Step 5.
- Proceed to the driver side rear tire, and repeat the procedure in Step 5.
- After hearing the confirming horn chirp for the driver side rear tire, check to see if the TPMS low tire warning light and the DIC LOW TIRE messages have turned off. If yes, the TPMS sensors have been relearned. Turn the ignition switch to LOCK/OFF.
If the low tire warning light and the SERV TPM message on the DIC are on after completing Step 5 for the driver side rear tire, the sensor relearn process has not been successful. Turn the ignition switch to LOCK/OFF and repeat the matching process beginning with Step 2.
- Set all four tires to the recommended air pressure level as indicated on the Tire and Loading Information label.
- Put the valve caps back on the valve stems.
Start with the first part of the procedure:
Then just start the truck, release the parking break and drive it for about 5 minutes. The truck will automatically learn the TPMS and the light/display will go out.
