1 - 20 of 61 Posts
GregDAP
Project Name
Install 3057 LED Bulbs in Tail Lights
Project Description
Replacing stock 3057 tail/brake/reverse bulbs with 3057 LED bulbs
Skill Level
Easy
Make: Chevrolet
Model: Colorado
Year: 2011
Engine: 3.7L
Power windows: yes
Sun Roof: No
Tools Needed
#2 Phillips screwdriver
Pliers
Heat Shrink(optional)
Double sided tape
Lighter or Torch for heat shrink(optional)
Liquid Electrical Tape(optional)
4 Red 3057(3157) LED bulbs
2 White 3057(3157) LED bulbs
2 6ohm 50w load resistors w/ 4 quick connectors
Project Time
1 hour or less
Project Cost
4 Red LED 3057(3157) Bulbs $45.00-$60.00
Here is what I used... 4X Red 3157 SMD 96 LED Stop Brake Blinker Signal Corner Light Bulbs Bulb | eBay
2 White 3057(3157) LED Bulbs $30.00-$50.00
Here is what I used... 2X White 3157 3156 127 SMD LED Back Up Light Bulb GMC Ford Chevrolet Pontiac 30 | eBay
2 6ohm 50w load resistors with quick connectors $7.00-$10.00
2X 6ohm 50W LED Load Resistor Turn Signal Fog Running | eBay
Heat shrink(optional) $3.00
Liquid Electrical tape(optional) $5.00
Double Sided Tape $3.00-$5.00
TOTAL COST: $85.00-$133.00 (depending on cost of bulbs and other supplies used)
Step One: Remove drivers side tail light assembly with phillips screwdriver by removing the two screws and pulling/prying the housing out .
Step Two: Remove the sockets/bulbs from the housing by turning the socket 1/4 turn counter clock wise(sorry no pictures of this). Set housing aside.
Step Three: Preparing load resistor(optional).
I choose to wrap the load resistor in heat shrink. I also slid a piece of stainless steel in there as well to help with the heat the load resistors generate and give me a better mounting surface for the double sided tape(see Step Six).
Step Four: Splice load resistor into signal socket wires by exposing the yellow wire from the harness that runs to the middle signal socket and using one of the quick connectors splice one of the load resistor wires into the yellow wire. The load resistor prevents hyper flashing when signal is engaged. You will have to cut the tape holding the wiring in the tubing to expose the wires
Pinch connector with pliers
Then expose and splice other resistor wire into the black(negative) wire that run from the reverse socket to the middle signal socket.
Step Five: Remove stock bulbs and install LED bulbs(make sure the white LED bulb is installed in the reverse socket).
Test them out to make sure they are working(brake/signal/reverse). Make sure signal bulb is not hyper flashing when signal is engaged. If any of them do not light up try removing the bulb, spinning the bulb 180 degrees and reinstall to reverse the polarity
I choose to coat the quick connectors with liquid electrical tape(optional)
Step Six: Mount load resistor. Please note that load resistors can become very HOT!! The longer the signal is on the hotter they become. DO NOT mount on plastic. The load resistors have small holes for mounting if you want to use some sort of self tapping screws. I choose to use double sided tape.
I cleaned the mounting area with an alcohol/water solution
Double sided tape
I choose to mount it here
Step Seven: Reinstall tail light
Twist sockets back into housing, stuff wires back into tubing, secure wires in tubing with electical tape and reinstall tail light housing
Double check lights
Repeat steps for passenger side...
PLEASE NOTE that passenger side signal wire is green not yellow... splice load resistor into the green wire on the passenger side tail light harness
Also some have used of a dab super glue to help hold LED bulbs in the socket. If you choose to use super glue make sure the glue is completely dry before reinstalling sockets into housing or the fumes could fog up the tail lights. The bulbs I used fit very snug so I choose not to use any glue. I have been running these for two weeks on and off road with no issues or bulbs falling out.
Night Pictures
:D:salute:
well done
Sent from my C771 using AutoGuide.Com Free App
Discussion Starter #4
Thanks guys... I'm just happy to contribute something easy that can make a truck stand out from other trucks. Especially at night!!
really nice write up. very easy to understand.
i wish mine worked properly. i did this a couple years ago, and if i have the stock bulb in the turn signal socket it works fine and is on all the time when the lights are on, but when i put the load resister and led bulb in the turn signal bulbs only lights up when i turn on my turn signals. i called superbrightleds.com and spent 45 minutes on the phone with them trying to figure out whats wrong and the guy couldnt duplicate the problem. i've tried different resisters, and different bulbs and it still doesnt work right. i gave up trying to fix it.
Nice! Good mod -- I was hooking up to my trailer today w/ LEDs all around and I was thinking to myself, boy LED tail lights sure would be nice.
Good How-To, I really would like to duplicate your work. The only thing holding me back is hearing how some people in years back have been unable to get this to work.
GregDAP, do you have LED running lights/turn signals up front?
Discussion Starter #9 (Edited)
Discussion Starter #10
i've never had a problem with mine:shrug:
What does the load resister do?
Discussion Starter #13
Read step 4
oh ratz, I missed that info in step four! Thanks, I've been wanting to do this, now I have no reason not to...
Thanks!
most people dont have a problem with it. my truck is just tempermental.
Discussion Starter #18
Your welcome... let's see some pics
Sent from my LG-P999 using AutoGuide.Com Free App
I did this mod yesterday, my negative set up was different. I had to use the black wire from the reverse light only, on both sides. Using the way Greg wrote it up gave my hyper flash city. I have a 2004
Greg did you do a write up for the DRL? I ordered the same set up you have.
1 - 20 of 61 Posts
