Popgoesdaweasel16
Project Name
How To LED your cup holder.
Project Description
How to LED your cup holder to give some extra lighting and provide a cool accent.
Skill Level
Easy/Moderate
Make: Chevrolet
Model: Colorado
Year: 2010
Engine: 3.7L
Power windows: Yes
Sun Roof: No
Tools/Materials Needed
Option 1 uses the battery pack that came attached to the LED strip. The option does not require any other power source except the included battery pack.
(This is the option that I used)
Use Option 2 if you want a permanent solution to having your LEDS on without the need for replacing batteries. Please scroll down for option two procedures.
Project Time
1 hour or less
Project Cost
FOR OPTION 1
FOR OPTION 2
OPTION 1 STEPS.
OPTION 2 STEPS
Popgoesdaweasel16
Project Name
Project Description
Skill Level
Easy/Moderate
Make: Chevrolet
Model: Colorado
Year: 2010
Engine: 3.7L
Power windows: Yes
Sun Roof: No
- Cup holder.
- Drill with 1/2 in bit and a smaller bit. (Width of LED strip.)
- Dremel tool.
- Two 4 inch LED strips. (One 8 inch pack.)
- Rocker switch.
- Black silicone.
- Soldering iron.
- Wire cutters.
1 hour or less
Project Cost
FOR OPTION 1
- $4 Rocker switch @ Radio Shack 16A 125V or 10A 250V DPST AC On/Off Round Rocker Switch : Rocker Switches | RadioShack.com
- $16 LED's @ Autozone LED Exterior Accessories | AutoZone.com
FOR OPTION 2
- Rocker switch
- LED strips
- $3 5 amp fuse @ Radioshack 5.0-Amp 250V _x_ Slow-Blow Fuse (4-Pack) : Slow-Blow Fuses | RadioShack.com
- $3 Inline Fuse holder @ Radisoshack 5-Amp Inline Fuse Holder for 5x20mm Fuses : Fuse Holders | RadioShack.com
OPTION 1 STEPS.
- Using wire cutters (not pictured) cut the 'try me' button off (about an inch down from it) the LED strip.
- Drill hole into drivers side of cup holder. Using the dremel tool, grind the edges of the hole so the switch can fit. Keep grinding and adjusting as needed.
- Tuck the battery housing up into the cup holder, right above the hole you just drilled.
- Pull the red wire from battery pack and black/white wire from LED strip through rocker switch nut through backside of drilled hole in the cup holder.
- Use the smaller drill bit (a bit wider than the width of the LED strip) and drill a hole into cylinder part of cup holder. Do this to both sides *I had already siliconed it in place before I took the picture*
- Peel off the 3M backing tape from the LED strips and stick them on the inside of the cup holder just above the little ridge on the bottom.
- Solder the red wire from battery pack to one side of the rocker switch. Solder black/white wire (attached to LED strips) to other side of the rocker switch.
- Protect the electrical connections with electrical tape or heat shrink.
- Tuck the wires and everything back into the cup holder. It should fit perfectly.
- Apply a dab of black silicone where the LEDs come into the cup holder.
- Enjoy your new illuminated cup holders!
OPTION 2 STEPS
- Using the wire cutters (not pictured), cut the whole battery pack and switch off at recommended spot from manufacturer. (Labeled on wires)
- Drill a hole into drivers side of cup holder. Then using the dremel tool, grind the edges of the hole so the switch can fit. Keep grinding and adjusting as needed.
- Pull power wire from positive side of battery inserting a 5 amp in-line fuse.
NOTE: Do not install the fuse yet bringing the wire through the firewall.
- Run power wire under door sill (gently lift up door sill, it should barely flex). Keep running wire under the door sill and bring it up underneath the seat to underside of cup holder.
NOTE: Don't forget to leave enough wire so that the seat can be adjusted without ripping out the wire
- Pull ground wire from either negative terminal of battery and go through firewall or you could also attach it to a bolt underneath where your footwells are.
- Run the negitive (-) ground wire underneath door sill just like the positive (+) power wire. Continue up under your seat to bottom of cup holder.
Note: Don't forget to leave enough wire so that the seat can be adjusted without ripping out the wire
- Pull the positive (+) wire through rocker switch nut through backside of drilled hole in the cup holder.
- Using a drill bit that is a little wider than the LED strip, drill a hole right above the bottom lip of cupholder. Do this to both sides and pull LEDs through your drilled holes. Then peel off the 3M backing tape from the LED strip and stick the strip just above bottom ridge.
- Take the positive (+) wire that is connected to your battery and solder it to one side of the rocker switch.
- Take the black/white wire that is connected to the LED strip and solder it to other side of switch.
- Solder the ground wire to solid black wire that is connected to LED strip.
- Install the rocker switch into cup holder and tighten the plastic nut that came with the rocker switch.
- Install a 5 amp in-line fuse holder on the postive feed wire.
- Turn rocker switch to ON and check LEDs.
- If LEDs work then silicone holes where LEDs go into cup holder and let sit overnight.
