1 - 20 of 36 Posts
gettingspeedy
Project Name
Sway Bar Quick Disconnect End Links
Project Description
Making sway bar end links that can be quickly disconnected for increased offroad capibilities
Skill Level
Easy
Make: Chevrolet
Model: Colorado
Year: 2004
Engine: 3.5L
Power windows: Yes
Sun Roof: No
Tools Needed
Hack Saw
9/16” Wrench
1/2" Wrench
Locking pliers
Parts Needed
Spherical Rod End Links (4) (Napa #732-1133, Dorman #116-203)
3/8" x 24 Threaded Rod
3/16” Lynch Pin (2)
5/16” Washers (4)
3/8” x 24 Lock Nuts (2)
3/8” x 24 Nuts (4)
Project Time
1 hour or less
Project Cost
$83.30, depending on region
Directions
Note: The measurements listed will work with stock, and suspension lifts where there are sway bar extenders, if you have early model skyjacker kits that replaced the end links, your process will be different.)
1. Park your truck on level ground to ensure that the sway bars are unloaded.
2. Remove your factory end links. Mine were rather rusty so I pulled out the sawz-all and cut them off.
3. Cut two sections of threaded rod at 4 ¾”
4. Put two standard 3/8” nuts on to each rod
5. Take two rod ends, add a washer, slide the end through the lower a-arm mount hole, add another washer, mark where you will need to drill the hole, and drill 3/16” hole
6. Screw on rod ends on to each end of rod, one end with out the hole drilled, one end with the hole
7. I tightened both rod ends all the way down, this is too short and you have to back them out, but this way you can be sure you unscrew each side equally. The side without the drilled hole goes through the sway bar, make sure to add washers on both sides, and then your 3/8” lock nut.
8. Same for the bottom, but instead of the lock nut, slide in your lynch pin and fold over
9. Tighten down the jam nuts
10. To disconnect simply remove the lynch pin and remove, make sure to not loose your washers. The end links will simply hang out of the way until you re-attach them. If you are worried about them hanging, a simple zip tie can be used to get them out of the way, I however wouldn’t worry about them.
This is a picture of the completed product, i didnt take any process pictures, you should be able to figure it out from this.
Anyone who would like these, but doesn’t want to actually make them, I will make them for you. You will pay ACTUAL cost of items, shipping, and $10 to cover my time/gas to get items. I will document with receipts that you are only paying cost for them, I’m not looking to make money, just an option for those who might not have time / tools / resources. However, parts alone are $83.30.
cool write up shame thats so damn expensive could you get clearer picture of it I wanna try this?
Its too hot in Texas!
Nice write up bro!! I am sure a lot of the offroaders will love this!!
Discussion Starter · #11 ·
I will take better pictures today; I might go through and make another set. They are both the same thread, after they are on you don’t need to adjust them.
Thanks guys, it was my first write up, I’m slowly making the transition to the nation.
good write up sound easy to do and thanks for doing the reaserch for us is there any way you could get some mor pix like one of it disconected
thanks for the pic i think im going to try this befor i go 4x4ing again but i think im going to make both ends removable so i dont have to worry about it binding up even though it might not
But there is no real need to remove you endlinks, your not offroading.
1 - 20 of 36 Posts
