1 - 20 of 41 Posts
Discussion Starter #1 (Edited by Moderator)
blurred
Project Name
How To: Remove Instrument Cluster
Project Description
You will need this to swap out gauge overlays, change needles, paint trim or any mod to the cluster itself.
Skill Level
Easy
Make: GMC
Model: Canyon
Year: 2006
Engine: 3.5L
Power windows: Yes
Sun Roof: No
Tool Needed
1 screw driver with replacement bits - 1 Torx (T10) bit and one Socket (7mm) bit -OR- 1 Torx Screwdriver and a Socket with a long extension (6"+)
Project Time
10 - 20 minutes
Project Cost
Free
Step 1: Start by removing the cluster surround. This piece is held onto the dash by ~4 metal clips on the back so it should pop off with a small amount of force.
Step 2: Once it is off, you will see the four screws holding the cluster to the dash.
There are two on the bottom as seen here:
Step 3: And two on the top corners, one of which is pictured here:
Step 4: Once those screws are removed, carefully slide the console out of the dash. There is a single wire that is plugged into the back. Remove that by pushing down on the top portion to release the clasp, then pull the "handle" to the left. This will pry the plug out of the housing, enabling you to remove it completely.
Step 5: Once the cluster is out, you can remove the clear plastic cover. There are seven (7) clips that hold it to the plastic surround for the cluster. Three across the top, two on each side, and two on the bottom seen here:
Step 6: To remove the plastic surround from the cluster itself, flip the cluster over and look for the five (5) torx screws on the back that bolt the two pieces together. There is one on the top center, two on the top corners, and two on the bottom seen here:
Once the screws are out, you can pull the plastic surround off and do what you want.
Re: How-To: Remove Cluster
Nice man, I already lost two of the four screws that hold the cluster in place LOL
How? dropped em back in the dash while re-installing? Next time use either a magnetic tipped screw driver or even a piece of gum to hold em on the screwdriver.
FAIL! go get more.
Eh, lazy. At some point I will :lol:
I know, I was in a rush and just kinda used what was easy to find at the time. Yeah, once they fall back there you're kinda fucked unless they found their way to the ground haha
Lol no shit...my clusters held in w/ only 2 haha. Once they fall theres no way you'll find 'em
lmao yeah to remove the gauges is pretty easy ive heard of alot of people removing the whole dash to get to it....good how to post alot of people ask how to all the time
[/SIGPIC]
Discussion Starter #12
Not sure. Just had a shit load of bits sitting around and tested one until it fit.
Just took my stock one out and put an extreme one in and I didnt have T-10 screws. My 05 had 4 7mm screws
Nation Citizen
thanks man! when I bought my cally, there was some smugges or something on the inside of the window. I gotta get that stuff its hard to see the numbers. eventually I am getting a custom cluster board but I like messing around anyways.
good right up I'll let you know how its turns out, or how many screws I lost....
Hey guys I have an led cluster I got to put in, how can I make the miles higher to match the current miles on my truck
Just plug it in reub. It reads your mileage from the bcm :thumbup: post some pics!!
Sent from my DROID RAZR using AutoGuide.Com Free App
1 - 20 of 41 Posts
