How to remove headlights
  • how
    Votes: 0 0.0%
  • to do it?
    Votes: 0 0.0%
1 - 9 of 9 Posts
Ok so this if my first thread so im new, I need to remove my drivers side bottom headlight on my colorado. I was wondering if anyone could show me how to remove it. If you have any pictures or even better a video I would really appreciate it. If your wondering I want to remove it because I have some condensation building up in there so I am going to re-seal it.
THANKS!!!!!!! :salute:
· Member's Technical crew
Too bad the pics don't work
ONLY for the how to on the grill. We will get that fixed as soon as we can.
Now, for removing the grill , you first need to remove the DRL's..they have a clip on the fender side of the light itself. Puch that clip in with a screwdriver. Once done simply pull the light out towards the center of the truck and she will come out. Once those are out, then use a flat blade screwdriver to pry each clip holding the grill in. they will be painfully obvious. there is one behind EACH DRL, one on each side of the center part of the grill, and one in the center of the grill. just put the flat blade between the metal clip and the support. Twist, and the clip will pop right out. To reinstall, just line each clip up one at a time or so..and push. The clip's will pop right back in.
Sorry no pics. We will get that fixed soon as we can.
The HEADLIGHT how to is currently up and running. So he can see how that's done.
Yeah,sometimes they can b a pita to get out, in my experience... But once u do it a few times it gets easier to do,
Just take your time and be careful
· Formerly Metal_EMT
If you need a host for the images, since the photobucket bandwidth went over. I'll host them on my website for you and give you the urls.
1 - 9 of 9 Posts
