1 - 2 of 2 Posts
Kunundrum
Project Name
Door Pin Replacement
Project Description
how to replace worn front door pins
Skill Level
Medium
Make: Chevrolet
Model: Colorado
Year: 2004-2012
Engine: N/A
Power windows: N/A
Sun Roof: N/A
Parts Needed
(1) – Dorman part # 38409 (one per door)
Tools Needed
Angle grinder with cut off wheel or Hacksaw
deep socket 10mm or larger
Vise
hammer
large socketed torx bit (or something similar)
10 mm socket & ratchet
Project Time
1 hour or less
Project Cost
About $20 per door, I got the pin kit from RockAuto for $14cnd.
Step 1: remove the door side of the door hinge, this will require a 10mm ratchet/wrench
Step 2: cut off the flared end of the old pin with an angle grinder or hacksaw.
Step 3: remove old pin from the hinge by pressing it out with the vise.
Step 4: Install bushings in the hinge (hammer them in gently)
Step 5: Inset new pin and press in with the vise.
Step 6: Press in the upper part of the hinge in using the vise (sorry did not take a picture of it) leave a small gap to allow for movement.
Step 7: Work the reassembled hinge to loosen it up a little, took a few wacks of the hammer to loosen it up at first.
Step 8: Re-install on the truck.
Notes: Check that the pins flared end fit in the original hinge, in my case the bottom pin fit perfectly but I had to open up the hole on the top one a touch to have it fit. I could have gotten away with only replacing the bottom pin as it was the one that was bad, but decided to do the top one too in order to make this How-to.
The new pin will be stiff for a little while.
Enjoy your non-sagging door
1 - 2 of 2 Posts
