rshadd
Project Name
How-to replace the orange cluster pointers with red pointers
Project Description
This a quick and easy mod to change your cluster pointers from orange to red.
Skill Level
Easy
Make: Chevrolet
Model: Colorado
Year: 2009
Engine: 5.3L
Power windows: Yes
Sun Roof: Yes
Parts Needed
2002-2006 Silverado Trailblazer Envoy Red Pointers.
Tools Needed
Project Time
1 hour
Project Cost
I picked up a set of red pointers on eBay for $40 shipped.
Here's how I did it...
This is a pic of the finished instrumentation cluster with the red pointers installed. It's a subtle change, but one that complements a red truck very nicely.
This picture shows the difference between the orange and the red pointers. The temp and fuel gauges are red, while the speedometer and tachometer still have the factory orange pointers.
rshadd
Project Name
Project Description
Skill Level
Easy
Make: Chevrolet
Model: Colorado
Year: 2009
Engine: 5.3L
Power windows: Yes
Sun Roof: Yes
Parts Needed
Tools Needed
- Fork
- Dremmel Tool
- Drill and Bit (.040")
- Nut Driver (7mm)
- Torx Driver (T10)
- Trim Removal Tool
Project Time
1 hour
Project Cost
- Begin by following Blurred's how-to on removing the instrument cluster.
- Using a small fork, carefully pry up on the existing pointers to remove them.
- The red stems have a longer stem that needs to be shortened. Use a Dremmel tool with a cut off disc to trim the stems on the new red pointers so that they are the same height as the factory orange pointers (approximately 1/8").
- The Dremmel tool tends to melt the plastic and clog the hole for the gauge pin. To fix this, drill a a very small hole in the red stems to match the pins in the gauge cluster. I used the smallest bit (.040") I had. Be careful that you don't enlarge the hole too much. You want a nice tight fit.
- With the orange pointers removed, replace them with the newly modified red pointers.
- Plug the cluster connector back in
- Re-calibrate the pointers. To recalibrate your pointers follow these steps:
- Switch your ignition to ACC with the cluster plugged in and none of the pointers in place, the "pointers" will all go to zero.
- Turn the key back to off. Now that they are at zero, carefully align the pointers to zero and press down.
- Start the truck and see where they sit. If you press them down too far, they wont move.
- If they aren't aligned correctly, pull them back off and try again starting from the beginning.
- Re-install the clear plastic guage cover.
- Re-install the cluster in the dash.
