1 - 20 of 50 Posts
Discussion Starter #1 (Edited by Moderator)
DawgCatcher
Project Name
How To: Shave Your Tailgate
Project Description
This is a mod that everyone should do, just because it cleans up the general appearance of the truck.
Skill Level
Moderate - Difficult
Make: Chevrolet
Model: Colorado
Year: 2005
Engine: 2.8L
Power windows: No
Sun Roof: No
Tool/Materials Needed
Compressor, grinder, air rotary tool, welder.
Project Time
2-3 Hours
Project Cost
$30 or less
Step 1: Remove the back access panel 4 phillips head screws.
Step 2: Then you remove the linkages holding the handle on.
Step 3: Remove the star bolts on either side of the tail gate holding on the straps for the tail gate, swap the rods on the latches, now comes the tricky part. If you have a relocate kit bolt on the handle to the provided plate and attach said linkages screw plate on and you are done, If you are like mc have your master fabricator make everything for you.
Here is the view with the handle removed.
Again if you have a kit test fit the filler panel and make and modifications to make it sit flush.
Step 4: Now take your means of destroying paint and remove the paint from the area as shown here.
Step 5: Test fit and then begin tack welding remember TACK welding you never run a full bead on fillers. start at either end and keep tacking every 2 Inches till you make it all the way around. remember switch sides often. I.e. 3 tacks on the left 3 tacks on the farthest side. Continue around till you have this.
Step 6: Grind down the welds till you have this
Then weld again to fill in any spots missed.
grind once again, then prep the area for body work
And for the finished product you end up with something like this
Have the shit painted and you are legit homies, now do this and stop bitching
Oh and thanks to mc for letting me have the opportunity (read that as finally deciding to do the right thing) to shave his tailgate.
  • Like
Reactions: for20
Re: How to be clean shaven on the backside
Good writeup dude...can't wait to get that painted this week. :yup:
3
Re: How To: be clean shaven on the backside (shave your tailgate handle)
Okies Dawg, thats sexy...I want :D
rrcn, you could always put it on a bus...thats another option
LA isnt far from Phoenix...drive your ass down here!
just out of curiosity, once youve shaved the handle...how do you open the tailgate?
the handle just flips to the inside of your tailgate where there is a stock plate that comes off. your handle will mount to that.
Discussion Starter #10
actually there is a special plate that must be fabbed or bought to do this
Re: How-To: Shave Your Tailgate Handle
got a quote from a local shop here in Hawaii. They are going to charge me $400 for this to be done. I don't have the tools. Do you think it's worth it? oh yeah, I told them to smooth out a dent i had on the tailgate also. so, is shaving the tailgate handle, and fixing the ding worth $400?!
i dont think so. shops here around my area only charge 150 and maybe 200 alltogther for the dent and paint
Deffinatly a lil high....:ugh:
Well, depending on the size of the dent they're fixing as well.
Nice, but you gotta da the area before you apply bondo try 80 grit
Meh, that's a matter of preference. I've seen guys do it this way, but most do it the other. I do it the other cause it's easier to sand when the bondo isn't flaking off the unsanded surface. lol
1 - 20 of 50 Posts
