Turbo EJ
Project Name
How To: Tint Head/Tail Lights from PDX Grafix
Project Description
I had a few people send me a PM asking what the Headlight and Tail light tint looks like. I tinted a DRL and a tail light tonight with the smoke color film just to give you guys an idea. Also below you will find a quick write up on how to do it. I don't have time right now to install the lights to show how they are lit up but once I get some time I will.
Skill Level
Moderate
Make: Chevrolet
Model: Colorado
Year: 2006
Engine: 3.5L
Power windows: Yes
Sun Roof: No
Tool/Materials Needed
-Tint Material
-Application Fluid
-Razor Blade
-Lint Free Towels
-Squeegee
-Hair Dryer or heat gun
Project Time
1 hour
Project Cost
cost of tint
Headlights:
Tail Lights:
Step 1: Measure how much material is required to cover the item you are trying to cover and cut out what you need. Clean the item to be applied and then spay down the object with vinyl application fluid.
Step 2: Remove the liner from the back of the tint and also spray the application fluid onto the back of the tint to lubricate it and kept it from sticking.
Step 3: Put the tint onto the item you are going to cover.
Step 4: Spay the surface of the tint with the application fluid to lubricate it so the squeegee will glide smoothly over the surface.
Step 5: Next start with the flattest surface you can find and begin to squeegee the tint onto the item. Working as much fluid as you can out of the flat surfaces.
Once you get to the point where you are going around a curved item you will need to get your hair dryer and heat up the material. As you heat the material stretch it out around the edges and smooth it out with the squeegee. Don’t be afraid to stretch the vinyl, just try not to heat it too much.
Once you get the material stretched around all the edges, smooth it out with the squeegee and then go over it again with the hair dryer. This will form the material to the lens and help remove all moisture.
Trim away the excess material and you are done!
Turbo EJ
Project Name
Project Description
Skill Level
Moderate
Make: Chevrolet
Model: Colorado
Year: 2006
Engine: 3.5L
Power windows: Yes
Sun Roof: No
-Tint Material
-Application Fluid
-Razor Blade
-Lint Free Towels
-Squeegee
Project Time
1 hour
Project Cost
cost of tint
Headlights:
Tail Lights:
