1 - 3 of 3 Posts
For the First 5mins. of driving, the alternator is @ 14.2V, then goes to 13.0V-13.1V and stays there.
Is the alternator going bad?
Nope, that's completely normal.
As long as it's putting out more than the battery voltage shows with the engine off (full charged battery should show between 12-12.4) , and your battery isn't getting squirrelly, I wouldn't worry about it that much.
Higher output after starting is normal, it's recharging the battery after the drain of cranking.
Also, factory gauges are notoriously inaccurate, no matter the make/model. If you really want to see what the charging system is doing, hook a voltmeter up to the fuse panel (any hot circuit will do) and get some readings there, then compare to the dash gauge for future reference. That'll do 2 things: 1 give you an accurate reading (assuming a good voltmeter), and 2. give you a reading far enough away from the alternator / battery to account for voltage drop along the wiring lengths). But this is all starting to border on obsessive - not that I've ever done anything like that, lol.
x2 what jamyers posted. I see the same numbers as you. the battery control module keeps everything in balance.
1 - 3 of 3 Posts
