1 - 9 of 9 Posts
So my truck won't start not even a crank. My battery is good and all grounds are good. I found a wire under the fuse box that appears to be pulled out. I do not know where it goes so if you could post a pic of the underside of the fuse box without the covers so I may see where this goes. Thanks guys!!
Discussion Starter · #4 ·
Sounds good asalinasz39!! 08Canyon no because I need the to see inside of the back of the fuse box. I think the wire in my hand popped out of there but I have nothing to reference to
What color(s)...looks like WHT/BLK...??
Discussion Starter · #7 ·
It's under the fuse box bro. Your going to have to unbolt it and remove the black cover under the fuse box where the main wires go in. Then snap a pic. The wire looks to be white with black stripe but could also be pink with black strip not sure. Thanks for the help guys!
1 - 9 of 9 Posts
