1 - 11 of 11 Posts
· Monkey Slut!
Yup, direct swap. The only thing that might be an issue is the oil pan is taller on the Z71 so if your lowered it will hand down lower than yours. Simple solution, just swap the pans.
Discussion Starter · #4 ·
Pan swapping I could handle, will the fuel system on my 06 bolt on?? Truck is stock except I am burning CNG. I would like to mill (mill, not just resurface) the head to increase Compression ratio a little, my mechanical instinct tells me this should alter valve timing. Any info greatly appreciated.
Thanks,
Fred
Discussion Starter · #7 · (Edited)
Thanks all!! I am looking at an 05 Z71 4x2 that's been wrecked. 200k on it, man sez it runs great, shifts great, AC even werx. Tailgate and doors good. He wants $1000, I had a business wanting $1995 for a motor with 61k. Should I try to get it for 8 or $900?
Thank you Jesse and FixxxerKH202!!! It's been a while! I'd like to share info on CNG. Thanks to a co-workers math and spreadsheet skills we decided to Mill the head 0.050" to get a compression ratio of 11.5:1. I did the clay on the piston trick with the top end mocked up, plenty of clearence! A word to your machinist! Set up the head on the "nodes/squish points" in the head. I had to cc the combustion chambers because the original milling was OFF! Runs well on 89 octane. You fellas still out there??
1 - 11 of 11 Posts
