I would start with seafoaming both the top end and injectors. If that doesn't work then I would move on to new plugs.
the injectors would be done with seafoam in your fuel tank. I pour a can into my gas tank before every oil change. Don't pour any into your oil unless you are ready to do an oil change.Thanks ststefan, Plugs were replaced about 2 months ago.Can I sea foam the injectors or does a mechanic need to do this.Seafoaming the top end won't be a problem.
Depending on when the fuel filter was last replaced, it could cause problems.I didnt gap the plugs,from my understanding they are already gapped.Could it be a fuel filter needing replacing
