1 - 11 of 11 Posts
Ok guys so I hooked everything up and I have no lights on my buttons. When I look at my wiring harness it has two orange wires that would be illumination type wires. I've hooked up to both and nothing. Next thing I did was look at where the pins are connecting with the stock harness and notice that neither one of those orange wires corresponds with a wire on the stock harness:rollg: So which wire on the stock harness has what I need so I can just go directly to that wire and tap it.
The harness you bought doesn't have a label for each wire on it? I used to buy them then return them just for the wiring guide.
Discussion Starter #4
They do but the problem is the two wires labeled illumination correspond to dead spots on the stock plug
Hmm, you installing a new head unit?
If I have a minute today, I'll yank out my head unit and see where my illumination wire is tapped from my Pioneer screen
Discussion Starter #6
Ya I have my eclipse in now but no lights on buttons. I'm tempted just to tap it to straight power just to make sure that they work (it's a used unit) But I know for a fact that the wires in the wiring harness that plugs into the stock harness go no where.
And It would be much appreciated if you could do that. Maybe a quick picture?
well thats because the stock harness does not have an illumination wire... they use DATABUS for illumination signal. If you dont have a chime module, that illumination wire wont work...
Bagged Bomber
yea thats what i would do. I cut my harness off and soldered(SP?) the wires on the unit direct into the truck. Everything works awesome except i wired my main power to the wrong key power wire so if i turn my ac off the HU turns off lol. Ill fix it one of these days
Now that makes sense I may need to get that. Maybe ill just tap it into a key on pwr wire
The closest illumination wire to the head unit would be the Hazard button, I think the solid grey wire is the illumination wire....
I can get you a Scoche (Spelling?) Chime module for $40 + S&H at a last resort for you... I am using this, they give you a Illumination, RAP, 12v Hot
Okay, what I did is pretty similar to what WwRGSwW is talking about.
I got the Scosche GM09SR and for me, the illunimation wire is the orange wire that you see on my harness.
1 - 11 of 11 Posts
