I'M ISO: 2007 GMC Canyon Looking for used or Refurbished REAR DIFFERENTIAL AND AXLES
638 Views 9 Replies 8 Participants Last post by  Iarado
MY NAME IS KATIE AND I LIVE IN PIGEON FORGE TENNESSEE I HAVE A 2007GMC CANYON 4CYLINDER REGULAR CAB TRUCK AND I HAVE A HUGE BLOWN HOLE IN MY REAR DIFFERENTIAL I AM SEARCHING FOR A USED OR REFURBISHED WHOLE REAR AXLE ASSEMBLY (REAR DIFFERENTIAL AND AXLES) IVE BEEN TOLD THAT MY 2007 GMC CANYON 4 CYLINDER 2.9 2WD AUTOMATIC REGULAR CAB TRUCK CAN USE PARTS FROM A CHEVY COLORADO AND A ISUZU. SO DOES ANYONE HAVE ONE FROM A WRECKED VEHICLE OR ONE FOR SALE FOR AROUND 300.00$ TO 400.00$???????? I HAVE NO CLUE WHERE TO START AND IF I CAN EVEN USE PARTS FROM A COLORADO OR A ISUZU .
1 - 10 of 10 Posts
The first thing you want to do is to determine exactly what differential ratio you have. Go look in your glove box for a label and look at the 3 digit codes Look for the ones starting with G?? I'm an guessing you will have one of these:
G80 Differential, automatic
GT4 Rear axle, 3.73 ratio
GT5 Rear axle, 4.10 ratio
GU6 Rear axle, 3.42 ratio
and possibly two with G80 (locking differential).
You need to match whatever you have now with those RPO codes.
Then you can start your search through rebuilders, Junk yards, and disassemblers.
  • Like
Reactions: 1
Then you can start your search through rebuilders, Junk yards, and disassemblers. ( I HAVE BEEN SEARCHING SO I CAME HERE A SEARCHING ALSO....
Thanks and YES I HAVE A 373 GEAR RATIO AND SPIDER RING SIZE IS 373 AND PINION TYPE IS 8.0 AND 6 LUG NO LOCKER. REAR AXLE REAR DIFFERENTIAL PART NUMBER IS #25814899 THAT PART CAN BE CROSS REFERENCED. I CALLES THE GMC DEALER WITH MY VIN# AND THEY GAVE ME ALL THIS INFO ALREADY . I NEED TO KNOW IF ANYONE HAS A USED OR REFURBISHED ONE FOR UNDER 250.00$ OR BETTER YER 225.00$ BECAUSE THATS WHAT I KEEP HEARING. SOMEONE HAS GOT TO HAVE ONE OUT HERE IN EITHER A WRECK ON THE FRONT END TRUCK OR A USED ONE OR REFURBISHED ONE THAT WILL FIT 2007 MY GMC CANYON 4CYLINDER 2.9 ENGINE SINGLE CAB PICKUP. IT BLEW A HUGE HOLE IN THE DIFFERENTIAL..
Try Car-part.com
or
LKQ
Welcome to the Nation. Lose the caps lock please.
I'm sorry the cap locks both you. I have a huge problem with my vision and I can barely see the small letters. I had to have my husband respond to this comment.
1 - 10 of 10 Posts
