1 - 9 of 9 Posts
Naiton Adovcate
I can't for the life of me figure out the figures for the injector tables. I have the 60 lb injectors and no matter what I input my truck doesn't seem quite right.
Thanks
maniac mechanic
PM cory 05quick4door he seems to have the easiest methods. I tried helping a few guys but they still had trouble dialing what I gave them to their trucks since it takes a bunch of tweaking from initial guesses.
Naiton Adovcate
Discussion Starter · #5 ·
I had been messaging him, but I think he's been busy. He hasn't responded to my last few messages about the problems I've had. Just really need to get it running soon. My family needs more than one running vehicle right now.
Call up Limequat (lime-swap.com). My 60lb injectors seemed to run great right away.
pssssssshhhhhhhhhhhhhhhhh
I used 80's in mine, what is the meaning of overkill? lol
My current setup uses 100lb injectors :)
Injector datasheets are on lime-swap.com under downloads.
You'll be chasing your tail if you don't get the offsets correct according to the datasheets. Also make sure your min pulsewidth is set correctly.
I had to mess with my 80's a bit to get them working good enough to get a decent tune done. They can be a little bit of a pain to get dialed in specifically for your truck but once you do, you will be good and will be worth it.
1 - 9 of 9 Posts
