1 - 5 of 5 Posts
I have a 2010 Canyon with a intermittent problem and would like to see if someone has any information about it. What happens is that I get 4 dings tones and then the word Fluid in the DIC display. When I look in the owners manual it says Check brake fluid. The fluid is fine and does not give me any codes to indicate what the problem is. This is a very random condition which may happen a couple times a week or go several weeks with out any thing. I do not think it is too serious unless it is something in the braking system starting to fail. Anyone have any idea what could cause it?
Loose/dirty electrical connection - check your wires and connectors for breakage etc.
Thanks for the information. I will check it out and I have some dielectric grease so will grease it up and see if that cures the problem.
1 - 5 of 5 Posts
