My truck has 265,000 miles on it and runs and drives great. Check engine light comes on, I record the codes, erase them and it takes about a month for them to reappear. Here's the list:
P0442, P0455, P0172, P0126, U1026, U1064,
I've replaced (in order) gas cap, Purge valve solenoid, and vapor canister vent solenoid. All A/C Delco parts. It runs and drives fine, but I've recently noticed a skip and hesitation for a few seconds when I first crank it up, but that went away a couple of days ago when I erased the codes. Any ideas guys? It's a rust-free truck, so I don't think there's a problem with gas tank rust around the fuel pump. This is a great truck, and I don't mind spending a little money on it to get things fixed if needed. I just replaced upper and lower ball joints. front hubs, inner and outer tie rod ends and sway bar struts were replaced about 6 months ago, so I like to keep up with all routine maintenance and do all the work myself. Just looking for any input from any of you that may have had these codes. Also, I replaced the exhaust manifold with a header about a year ago and did a cat delete on the main catalytic converter (not the pre-cat in the header), and used the spark plug anti-fouling adapters to "trick" the computer into thinking the cat was still there. There were no codes after that little trick. Hopefully ya'll know what I'm talking about there.
Thanks in advance for any input. I love my truck and want it to last forever!!
