1 - 6 of 6 Posts
Discussion Starter · #5 ·
No I bolted it all right. I just had to loosen the sway bar and then used the stock end links. It was about a 1 inch distance between the LCA and where the swaybar was originally. So I adjusted the sway bar so that I could use the stock end links
pretty sure everyone uses the stock end links... but if its a fresh install you would prolly have to completely remove the sway bar to get end links to line up... but after that should be easy....
1 - 6 of 6 Posts
