1 - 15 of 15 Posts
Not the heatshield its secure, all clamps are tight and secure, filter has been freshly recharged. there is a high pitch rattle at 1800 rpms through every shift. If ur traveling slow like me, sometimes you'll stay in that rpm range for a good lil while, and its so loud that other traffic can here it. Theres no way that its the normal breathing sound from the filter. Almost sounds like a Heatshield to be honest. Also this only happens while driving, if in park and reved it won't do it at all. any ideas?
It's not the heat shield?
hmmm...check the bolts securing the bracket from the block to the intake pipe?
Thanks for cleaning ^^^^^ that up. but uh yeah MC i i checked the heatshield around the filter it is completely secure theres no way thats what is making the noise... i've even started to wonder if it could be a heatshield under the truck, but i swear it sounds like its coming from the right front intake area.
i can hear my cat rattle once in awhile.. like the shiedl around the cat rattles .. u could check that
3
check the heat shield on the manifold too, mine used to rattle around 2300 rpm but it fixed when I had to take it off to gut the cat...after I put it back on the noise quit.
Edit, I think there was a TSB for the manifold shield rattle...I think...
Ah! Ya know what...mine makes the same damn noise...and, I believe it's from the fan shroud area...something's loose in there. It'll probably go away when I do the e-fan mod, but, if it doesn't...:shrug:
It gets worse with acceleration...doesn't really do it at idle.
Dealership told me they couldn't fix it. :bs:
Discussion Starter #8 (Edited)
thanks guys. basically i need to get the truck in the air and check every heatshield all the way down the truck from front to back. The other day i was in another vehicle driving next to mine while my brother drove and i could hear it plain as day. Pretty freaking embarassing if u ask me. Now im ashamed for letting it go this long.
Well I had two exhaust noises I delt with. One was the manifold heatshield.. But that was around 2k-2.2k Rpms.
What you are describing is the next problem I fixed. The manifold has a small heatshield welded to the bottom of it. That sun of a bitch made all its noise at 1800rpm - 1900 rpm. Mainly on takeoff. Remove that thing with a prybar, the welds are real weak and weaken even further over time. See that POS right under the cat and above the collector?
gerry the pics don't work for me.. it says bad link..
Discussion Starter #12
When removing a heatshield like that. is it possible that now with the extra heat in a lengthy time it would dry out the rubbers in the suspension areas. thats what i've always been told about replacing heat shields.
If you see the weak spot weld on top, you will find it was not engineered for the heat... I can not see anything that shield is truely protecting. I am assuming it is for road debris that might hit the pipe. A new manifold is $300+...or maybe spot weld that back on... Your call, if that is even your rattle.. Get in there and check her out..
Discussion Starter #14
alright i crawled under that and i can definately see where the welds are bad. but i hit it a few times with a rubber mallet and didn't here anything at all.
Same deal for me, everything looked and sounded tight enough while checking it... I had to do process of elimination, I took off everything else (other shields). It was the last component that could cause the noise.... I could not replicate the noise unless the engine was on and under load. I had a spare manifold, so I did not hesitate to take it off and that was the problem... The top weld was the weak link..
1 - 15 of 15 Posts
