The thing with torsion bars and keys, there is no 'set amount'. I specified 24" because that is a safe number. You can squeeze about 1/2" more out of it (maybe). I can't go higher on mine without doing damage. The keys and torsion bars have more adjustment, however. If I lift more, I will start banging parts together that are not meant to touch. Key designers have a reindexed hexagon that twists the torsion bar beyond what the factory keys will allow. In general, on a good torsion bar, it should net around 3", that's why it is advertised as a 3" lift key. Individual results vary.
The higher you lift the front, the less likely it is you will get it to align within factory specs. The ride could be so hard you can't control the vehicle very well. You will bind the UCA/ball joint which may lead to cracks in the UCA. etc.
I sit almost exactly at 24" (total coincidence) and if I am going through a curve that is bumpy, I do not have control of the vehicle. The suspension can not cycle quickly enough and the front end 'skips' across the lane somewhat. In the direction of body roll.
When I did my spacers (the same ones Greg has) I removed the bolts and took them to a wire wheel to clean them off. Then used a few drop of Blue Loctite. Just to take up that little bit of space in the threads. I can still remove them that way, if needed. This is not necessary as there is no thread locking agent on the stock bolts.
I may have confused you with my previous comment. You will not gain lift from lowering the differential - if you are lifting to allowable tolerance, the differential should be lowered to prevent half shaft/CV damage. The way you wrote it, it made it sound like you want to lower differential to get max lift. Sorry if I confused you.
